WD sputtering
jarrod318 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jarrod318 Quote  Post ReplyReply Direct Link To This Post Topic: WD sputtering
    Posted: 03 Aug 2016 at 3:46pm
Hello again - Tried mowing my pasture today but the WD is sputtering really bad. I was low on gas and at first thought I was empty so I added more gas. After that it started sputtering really bad. I was able to get most of it mowed but stopped after awhile afraid I was going to make it worse.
Any thoughts or direction on where to start trouble shooting would be much appreciated.
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 3:53pm
water in gas or fuel blockage problem in the line, sediment bowl at tank or in the carb float vavle.
littlemarv View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote littlemarv Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 4:04pm
If you ran it down to the dregs probably clogged fuel flow.......
The mechanic always wins.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 8:24pm
Foul some plugs? Better look at them. Plugs tell the story. Learn how to read them.(everybody should learn)//
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2016 at 9:01pm
One of the WD's, (Jack's) has been running bad and constant sputtering to the point it sounded like a (John Deere)! Adjusted the carb and reset the timing. A little better but still not good. Called NAPA and they said they had a set of 458 (hotter plugs)That made a bunch of difference! Almost sounds like a Allis again!
