maroon 7080 vs black
19856020 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 19856020 Quote  Post ReplyReply Direct Link To This Post Topic: maroon 7080 vs black
    Posted: 02 Aug 2016 at 3:55pm
are there any differences between mb & bb 7080's other than shifter on floor also same question of the 7580 . thanks for any info
716 917 918 1920 d17 6080
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 4:30pm
Later black models had more lifting power at the 3-point hitch. Very late models had Bosch injectors. Several other little things were changed.
Mike Kroupa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike Kroupa Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 4:34pm
Maroon chassis 7080 used scavenger pump to transfer leak-off oil from power director housing to the georotor sump housing. Black chassis used a sump under the power director housing and steel tubing to gravity flow oil back to the gerotor sump housing. Much better system. I would think black 7580 would be this way also. Late 7080's had increased 3-point lift capacity. I have a 1980 7080 and mine does not have increased lift capacity. It was a serial number break thing and was carried on into the 8000 series. I'm sure others will add more. Mike
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 5:04pm
If I remember correctly, there were some improvements made to the variable pressure/variable volume pump system also.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 6:50pm
Gravity flow oil back to the pump sump was before the end of the maroon series and all 7580's had it, so late 1976 I think.
