6060 is which Fiat tractor?
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Topic: 6060 is which Fiat tractor?
    Posted: 02 Aug 2016 at 6:51am
The 6060, 70 and 80  are the same Fiat tractors with an Allis engine, is there a Fiat branded tractor that is identical?  Probably would have a Fiat engine.   Might be a simpler source of parts.
Bill
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 7:17am
The rear end was Fiat (transmission back), that was it.
Never heard what that went to. I guess you could search Fiat models of the late 70's/early 80's and match them up.
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 7:24am
Maybe a Fiat 880? (I think that matches a 6080)
Charlie
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 11:12am
Heston 890 sort of.
Acmike View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acmike Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 1:06pm
there are other differences although they may use some of the same parts things like gear ratios are different,found out the hard way.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Aug 2016 at 5:08pm
6060 Used trans and rear end from a Fiat 780.  6080 used trans and rear end from a Fiat 980.  I think there are more 6000 AC tractors in North America than Fiats!  However, Fiat has also supplied other manufacturers with drive train components as well.  The best place to start looking for parts is your local AGCO dealer (although mine is 2 hours away from home).
This page was generated in 0.048 seconds.
