WD45 Air Cleaner Hose
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Air Cleaner Hose
    Posted: 19 May 2010 at 6:58am
I need to replace the hose from the air cleaner to the carb. Service manual says to use only the hose provided by AC as radiator hose will collapse. Parts manual lists it as #226266. I've used radiator hose on other tractors but the run is much shorter. Do you guys agree with the collapsing business and is that part # still available? Thanks.
WC, CA, D14, WD45
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 7:02am
just get a radiator hose with the wire in it. or you can slip the wire spring in the hose of your choice. I have been running one like that for over 20 years
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 7:03am
It's been way too long but I think there's spring like spiral wire inside the hose to keep it from collapsing.
Dusty
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 7:04am
I did a wd45 6 yrs ago for my cousin and the hose was $28 which about floored me .But it able to be bought.I use radiator hose now only because I have 200 boxes of 3 ft lengths of radiator hose that came with my shop. radiator hose will breat down but I have seen alot of the new hose that is suppose to be gas resistant break down too.
Jeff(WC)(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff(WC)(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 7:14am
just replaced both wc and wd45 hose....they are different...45 is a lot shorter and bigger than wc hose...bought both from agco....10 for wc and 26 for wd45....a little steep but i had radiator hoses collapsing on me
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 7:27am
Thanks, guys. I noticed in the parts book that the WD45 hose has a different part # vs. the WD hose....I suspect that styled WC and WD use the same hose. One thing about the price.....local auto parts stores will only sell radiator hose in standard lengths - I think minimum is 3 feet - and the cost gets up into the upper teens. So the agco price isn't too nasty in comparison, and maybe I can talk myself into spending the bucks.
WC, CA, D14, WD45
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 8:11am
I bought a piece of what appears to be flexible aluminum hose (reinforced with internal wire) for my WD at a local auto parts store. Cost less than $10.  Works great.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 8:17am
I used a radiator hose from an auto parts store and I haven't had any problems. It doesn't have any wire reinforcement.
Just get a section of radiator hose with the proper amount of preformed bend already in it, then cut both ends to the correct length. I wouldn't use a straight piece, then bend it because it will kink.
My piece of hose has been on the tractor for years and hasn't started to deteriorate.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 9:11am
I can not tell the difference in the $34.45 hose and the $16. Advance Auto, Dayco B71598 that can make 2 hoses, 98% close to original. Maybe someone else makes that hose heavier, never checked? You can search their rack and find a piece that will make 2 hoses if cut in half. If it gets weak, replace it every 2 years with a new shiny clean one for 1/4 the price of AC.
   I have heard they collapse, but working hard or dyno, mine won't.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 1:09pm
Thanks, everyone! I ended up talking with Albert at Dean Ag and ordering the AC part.......partly as an experiment to see first hand just how it compares to an off-the-rack part at a car parts store. Will let you know what I find out.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 1:47am
I wasted 34.45 to see the difference. I can except the cheapo for all except perfect restorations, I didn't give myself a citation.
2014 HD Tri Glide
Bob D. (La) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob D. (La) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2010 at 4:49am
Though it's not correct, I use the hose from auto parts stores that you find on all 95 and later vehicles. Comes in various sizes, is expandable metal with spiral wire core and works great.
