What's this? it's leaking oil
Dutchboy Johan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Topic: What's this? it's leaking oil
    Posted: 19 May 2010 at 3:25am
I find out that it's something with the hydraulics, but it's leaking and it looks like its damaged. Can someone tell me how it should be or can post a picture of how it should be? And the other question is, can i repair this with new a sealing?
Edited by Dutchboy Johan - 19 May 2010 at 3:26am
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands
Allis-Chalmers 190XT Ser.III #26829XTD
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 5:37am
That tube that goes to the sump has a seal on it.
"Burgie"
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 9:50am
Both those tubes have a rubber seal on em.  Try tightening up the bolts that go thu the cast house as that will squeeze the seals tighter, might work, might not.  If not you need the rubber seals, drain all the oil, then take the oil manifold off, make it easier to put the seals on, will need an oil manifold gasket too, then you can clean it out too.  This is a common leak on 190s and 200s.  HTH
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 3:22pm
In the picture below you see 2 arrows that i drew. Is hole normal? It looks to me that it's damaged by something. If it so i would like to try to fix it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 4:07pm
Sure looks like something is bent to me.
