wd45 block value
what66 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Topic: wd45 block value
    Posted: 26 Jul 2016 at 8:59pm
Hi guys I'm looking at a block with stuck pistons and a good crank
I want to rebuild it so I don't have to disable the tractor until it's ready.
What I would like to know is what do you think I should offer for it?
He says that the block is good but the sleeves and pistons are rusted in place.
I would like your advice thanks all.
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2016 at 9:51pm
If the block is not cracked anywhere it could be worth $150/$200. You cannot tell if the block is not cracked until you pull the sleeves to look at the bottom webs. I went threw 3 blocks before I found one that was not cracked on the bottom. I made the mistake of assuming the blocks where good before I removed the sleeves. If you want to take the risk offer him $100. If the crankshaft is good, it will be worth that.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jul 2016 at 10:45pm
Thanks.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 8:14am
I'd make a deal with the owner you will strip the block down and have it checked before paying for it, then you are not paying for a bad block. I don't buy blocks without making the deal of pay after it's checked out or pay for it with a deal of refund if it's not good.
I have a pile of junk blocks now. lol
Edited by Don(MO) - 27 Jul 2016 at 8:14am
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 9:26am
Tell the guy to take it apart , then u can check it out . If u do not know what it is DO NOT buy it ,that's what I would do.
nonetheless ,still dead.
EricPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EricPA Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 9:54am
Don and Fred have good points might not be cracked now but who knows what could happen during the piston/sleeve removal
Life is tough,but it's tougher when you're stupid. - John Wayne
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 10:55am
I carry a piece of rough emery cloth with me. If it isn't cracked on the top between sleeves, I doubt very much that its cracked on the bottom. Not to say it can't be, but I've never seen that scenario. I bought one just like what you're looking at a year ago for $75....as-is... my risk. Block and crank were very nice and had a lot of parts left over.
Post Options Post Options   Thanks (0) Thanks(0)   Quote what66 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 6:19pm
Thanks for all the help guys I'll wait until I see it to decide I'll let you know.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 7:04pm
Don, Fred and DrAllis (along with a few others) , in my opinion, give some of the best advice on the forum!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 10:15pm
Perhaps you should ignore my response. It doesn't seem to be worth even 2 cents to some people.
www.awtractor.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 11:53pm
I certainly did not mean to slight Alex or anyone else. I apologize if I implied that. I was trying to point out that he had responses from several of the most respected posters on the forum.
