wd45
kj@junction View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kj@junction Quote  Post ReplyReply Direct Link To This Post Topic: wd45
    Posted: 18 May 2010 at 7:36pm
Have wd 45 that has combine tires on the rear, needing to replace old front tires question is how much bigger tha 6;00x16 can you go on the front hope to level it out a bit. will 7;50x16 implement tires work, looking for something that won't tear up grass when turning. kj
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 8:50pm
If you have a NF on it the 6:00x16" is about all that will fit in there and not rub.
If you have a WF then 7:50x16" will work, you might need to get wider wheels and run them turned around so they don't rub.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote kj@junction Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 9:48pm
was afraid of that  oh well thought maybe someone had done something like that before kj
