Hd5g parts
DavidnTenIll View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Topic: Hd5g parts
    Posted: 23 Jul 2016 at 8:31am
Looking for hd5g engine clutch shaft and front yoke with good tight splines.
Dozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dozer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2016 at 4:26pm
General Gear   Please post if you find a new yoke.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2016 at 6:59pm
that front yoke might be a problem as I found 1 out of about 8 I checked -
Clutch shaft - around but also hard to find a good one with no wear - couple I had were worn at pilot bearing end as well as splines .
 check that brass bushing in the throw out bearing area also for wear as that will cause shaft to wobble . I turned a new one from brass bearing I took from metal polishing machine
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2016 at 7:30pm
Yep contacted GG but haven't heard anything back yet. Appreciate the responses.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2016 at 10:03am
I have a cluch shaft 19inchs longues and have 1 yoke with U bolts and 1 with joint bolt on yoke
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2016 at 4:55pm
Gem dozer I sent you message should be in your inbox. David.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DavidnTenIll Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 4:34pm
Gem dozer sent you message and email to your inbox.
David.
This page was generated in 0.240 seconds.
