$$$ items for sale$$$
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Topic: $$$ items for sale$$$
    Posted: 18 May 2010 at 12:07pm
Several things around the shop that I would like to move out of the way and maybe get them to someone that needs them.
     I have a good WD 45 Gas block...cannot find any cracks in it
     Trip loader that came off a D 14
I also have some good parts that someone may be needing.
      Intermediate PTO gear for WD and or WD 45...this is the one up in the main body
      Press on cam shaft gear for WD 45
      I have a couple of hydraulic pumps for WD/WD 45 that we have gone thru and
             tested.  They test out at around 3000 pounds with good volume,  These
             pumps have new gaskets plus have had a new rod made and the holes
             recut so there is no play in the control rods.  We can rebuild them but they
             would cost a lot more.
      I also have the 4 studs that are used to install the gear on a WD or CA for the
             rear mounted grain drill.  These are the studs that take the place of the
             4 rear lug bolts that are removed and allow the mounting of the gear.
Email me for prices and more info and pictures at     dennisstork@hotmail.com
I'm located in Southern Illinois for those items that can't be shipped.   Den
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 12:09pm
That sure did not come out the way I typed it.  Den
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 7:03pm
bump
This page was generated in 0.052 seconds.
