Anyone know what amp alternator a 200 has (stock)
Daniel Christensen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Topic: Anyone know what amp alternator a 200 has (stock)
    Posted: 18 May 2010 at 10:26am
On tractordata, it listed the 200 as having a 28 amp alternator.
I believe it's been removed now as I emailed him and he said he had no idea where that came from and he asked me what I thought it was. Now the alternator is not listed, which is better than being wrong but does anyone know what it has?
Edited by Daniel Christensen - 18 May 2010 at 10:28am
CAx3, Bx2, G, D17x2, D14x2, D15, D19, 190XT, WC, WD-45, 185, Gleaner K.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 10:36am
Mine I believe has a 55 amp , its factory and I just had it off the other day ; its also got a YEARROUND cab on too ; my 180 has a 35 amp- have no idea if its factory ; just had it off too ; both are DELCO; I would say it depended if it came from ALLIS with a 2 battery setup;
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 10:38am
So the 200 is Definately 55 amp stock?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 10:38am
If its a Delco, a 28 amp version would be a "DN" series that uses an external regulator to monitor the charging chores. Delco's have there I.D. number stamped in the chassis near the top mounting boss. Shoot me that number and I can identify it for you...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 10:42am
Wait so you're saying the 200 might have really had a 28 amp alternator stock? So maybe that wasn't a mistake on tractordata?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 10:53am
No, what I'm saying is if its a Delco, I can I.D. it for you by the P/N to see what amperage unit you have in service on your tractor. I'm not familiar with the 200 and what came on it for a OEM Alt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 11:46am
Well I don't actually have a 200 so I have no numbers. I was just wondering so it could be corrected on tractordata. I suppose a 28 amp alternator would actually be fine on a 200, because think about it the JD 9630 only has a 200 amp alternator! And that's full of electronics and has a huge motor.
Joe(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 11:58am
I just changed the alternator on my 190 XT and it had a 32 amp on it.
 Joe
Life is simpler when you plow around the stump.
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 12:38pm
32 AMP alternators were common in those days.  180s,s185s,190s,200s all had delco alternators with external regualtors, and 170s and 175s to.  hth
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 1:13pm
Wow, then I guess I won't be taking the 190 alternator for my pickup then! It always reads +40 on the amp meter so we always turn the key off so it doesn't overcharge. I think it has a bad regulator.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 1:26pm
I think turning the key off could do harm to the alternator. Overheats if I remember.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 1:31pm
I don't think it does cause we always do it so it doesn't overcharge the battery.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 1:39pm
If I remember right the instructor at tech school told us that if you don't give a place for the output to flow it will overheat. That's just what I remember. Been awhile, almost 20 years.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 2:25pm
55 amp was standard when equipped with a factory cab.....32 amp std on platform tractors. Most had a 55 amp installed when a 32 amp failed.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 2:31pm
DrAllis, what's your knowledge with running with the key off?
Wink
I am a Russian Bot
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 2:59pm
   Its my understanding that if the regulator is working that a alternator should stop charging when the battery is fully charged.
http://www.rumelyallis.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 3:52pm
Ah see but ours we figure has a bad regulator and wouldn't stop if the battery was fully charged; that's why we turn the key off. Actually, our 190 alternator did just go bad and we had it redone. But this is after years (10+) of using it. We've never replaced it before.
Gordon,scia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gordon,scia Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 4:25pm
It was always my understanding that in order for an alternator to charge, it had to have current to it to charge the field.  Hence, if the key is shut off, no current so no charge.  Please correct me if I'm wrong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 4:34pm
As a battery reaches 14.6 volts the alternator should have less field and deliver less charge.  A fully charged but idle 12v battery has 2.2-2.4v per cell and 6 cells so at idle or engine off it should read around 13.2-14.6v.  A alternator does need to deliver a current to a storage cell to keep from overheating but only if under field voltage, no field no current.  The problem lays with the constant full amp charge from the alternator when it does charge, it will force the lead sulfate from the battery plates at a higher rate than normal and kill the battery sooner than a normal time frame, it can also lead to a battery failure(explode) if allowed to continue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 4:48pm
most alternators need a signal voltage to get them started, with the key off, you should not have anything available to tell the alternator to charge, even tho the alternator is spinning.  YOu need excitation of the field as Gordon said.
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 5:12pm
Think your thinking of a generator for having a place for the current to flow.
 185 literature says standard was 55amp, didn't say with cab or not, of course all the pics were without cabs.
 just rebuilt nephews 200 alternator, stuck in the 78 amp windings.
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 5:22pm
My 1972 price list shows 32 amp as standard, with the 55 amp being an $8.00 option.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 6:36pm
Hahahaha 8 dollar option. There's a thing of the past.
