need onan spark plug wire part #
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: need onan spark plug wire part #
    Posted: 14 Jul 2016 at 8:28am
anybody have the correct part number for the 616/620/720 tractors?
Thanks!
Rod in MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rod in MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 2:11pm
HI, Is this what you are looking for
Rod in MN
Onan 167-1602 Spark Plug Wire Kit CCK B, P & N Series.
167-1602 Spark Plug Wire Kit. CCK, B, P & N Series. Resistor type with Copper Conductor. This SINGLE 23" long wire can be cut to desired...
$16.40
Add: < name="products_id317" ="text" size="4" value="0">
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 2:52pm
Steve at B&B, has the best wires. You will not be disappointed!HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 6:07am
Thanks Tracy! Appreciate that! Dave I offer a spark plug wire set for the Onans. If ya just need one, I can just ship ya one if ya want. Just need to know the type coil used. Some had a pin in the coil where the wire pushed onto and the cap screwed onto the high tension tower, some might have been replaced sometime in its life with the standard "boot type" coil. Can build either one for ya...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2016 at 7:24am
push on style Steve, thanks!
This page was generated in 0.115 seconds.
