28 inch rear wheels
playsindirt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote playsindirt Quote  Post ReplyReply Direct Link To This Post Topic: 28 inch rear wheels
    Posted: 14 Jul 2016 at 7:47am
can I put wd rear wheels on my D-15. I can find used 28 inch rims and tires all day. seems 26 inch are not as common. Thanks.
48G 49B 67D15 35picker allcrop60 1973 rotobaler 49C
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 7:52am
The complete rim and spin-out center will fit a D-15, yes.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 8:16am
D-15 should have had 28 inch tires in the first place. What were they thinking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 8:20am
If there isn't any fender issues that's what I'd do.Have 14.9's on the WD and you can't set wheels in the last notch but don't need that setting anyway.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 8:22am
That's one of my arguments why a even a D-15 II never really replaced a WD-45 on a 3-16's mounted plow in tough going....less rubber and less engine torque.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 8:27am
If the tire has traction the slightly small diameter gives more pull for a given ground speed and engine power. The trade off is the bigger tire often has more area on the ground and so is a bit better at converting torque to pull. Its also affected by weight on the tires, type of tire (bias vs radial, radial always pulls better), engine torque and gear ratios.
A two inch larger rim with the same cross section tire also means the axle housing clears the ground by another inch, handy when cultivating or spraying row crops.
Gerald J.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 9:03am
The taller rear tires could make it tough to hookup snap coupler equipment. I have 16.9-28's on my WD45, and unless everything's perfect I usually have to jack up the snap coupler hitch 1-2 inch to get inside the bell.
Adam Stratton View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Adam Stratton Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 11:48am
I have 14.9 x 28s on a d15ii and it works just fine for me
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 3:47pm
Make sure you use the rail stops, if the eccentrics don't hold the tires will hit the fenders.
ALLIS EXPRESS!
This year:
