Cutting Hay Pattern and Swing Tongue Swather
rlrobinhood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Topic: Cutting Hay Pattern and Swing Tongue Swather
    Posted: 10 Jul 2016 at 4:12pm
Hi all,
Well, I put up my first crop of hay.  I think I did it in the most in-efficient way possible, but I learned a lot.  And have a lot more to learn, lol.
Both my swather and baler are Allis Chalmers and have the swing tongue on them.  When I would get to the end of my row, I can turn tighter to the left and very wide to the right.  I never tried unlatching the tongue.  I'm assuming that I should have at the end of each row.  I also learned that I need to pay a lot of attention to the rear tires of my tractor hitting the PTO shaft if I try to turn too tight.
Can you provide me with some guidance on the cutting pattern I should make in a field and how/when I should pull the rope on the swing tongue latch?  I'd really appreciate it and thanks for your patience on the "simple" questions.
kev/ont View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kev/ont Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 4:19pm
You pull the latch and swing the tounge to the open position before you turn on the pto. It swings the machine out away from the tractor and also provides you with better angles of turn and allows the pto shafts to turn on the right angles. You run the risk of serious driveline damage if you run the pto with the machines closed in.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 4:26pm
OK, so I'm very new to this.  But, I think you are saying that I don't turn the PTO on till the swather is off to the side?  If so, that is what I was doing.  But, once the swather was off to the side, I never touched the swing tongue latch.  I kept the swather off to the side the entire time.  Is this the correct operation?  Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 6:20pm
Yep, Operating in the transport position will eat up your driveline...
ac45dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac45dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 7:47pm
obtain the operator manuals for your equiptment.this will cover most everything you need to know for safe and efficient operation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 7:57pm
You should be able to turn right much easier with both machines. If you do it right, when mowing, you go till there is just shy of the width of the swather between it and the side of the field you are turning to. Then when you turn, it all gets cut.
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 8:44pm
When your swather is folded (more behind then beside the tractor) this is called transport position and that is all it's supposed to be used for. These things take a little learning just like everything else. A manual would be a very wise investment
Also I've found with a swather,and most other drawbar equipment, it helps to remove the 3pt arms. If you're not using them, get them out if the way.
Edited by thendrix - 10 Jul 2016 at 8:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 8:51pm
Hi all,
Thanks for all the information.  I do have the operator's manual, but it doesn't actually talk about operating it.  Just setting the machine up.  So, what I think I'm hearing from you all is that you put the tongue in operation position (swather out to the side) and just leave it there.  Make wide turns to the right and slightly tighter turns to the left.  Am I hearing you right?
Again, many thanks!!
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 8:54pm
Tighter turns to the right, wide turns to the left.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 10:36pm
With that type of machine we always went around in circles, always turning to the right. you have to run over uncut crop if you try an turn left. Now a person could lay off some "lands" like moldboard plowing if ya just have to go up and back.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 7:20am
I think the perspective of the turn might be the issue here. I've never run the model of mower you mention, but I've been mowing hay with that style of unit for....35 years or more?
First, yes, swing the machine out and leave it there. I can't imagine the time and misery involved in switching the tongue on every turn, and it's not going to do you any good anyway.
Back to the perspective thing. You're sitting in the tractor seat, and it may not seem like you're turning sharp. But look at the outside end of your mower. You can turn so that it's virtually stationary, even "backing up" slightly. You can turn short enough to the right, so that your back tire doesn't come into the tongue, and a little driveline clatter is OK. As you approach the corner, you're going to bring the cutter bar just to the edge of the standing crop, and turn sharp to the right, watch the back tire, and watch the outside end of the mower, and keep into the turn. About the time your front tractor tires are approaching the standing crop, turn to the left as quick as you can. Watch the outside end of your mower, and it will actually be backing up and you'll swing right into the cut. A little practice, and you'll make slight adjustments to what I just said and you'll get the hang of it.
On sharp corners, acute from 90 degrees, I will often cut the full point off the angle and swing around to the left. When you turn left, for me I think, there's less clatter in the driveline, and it seems like you're moving faster. In fact, if you have a hi lo and are in lo, flip it in high for the corner (Only for these left hand corners). So you are moving the mower faster, but not really saving time or turning sharper. Make sense?
Edited by Tbone95 - 12 Jul 2016 at 7:22am
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jul 2016 at 12:08pm
I agree with TBone. I used to pull a 488NH for years. The far side of the mower will back up on a right turn. I pull a 13' disk bine with the 8050 and it does the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jul 2016 at 10:41pm
Thanks TBone.  I'm still not sure I understand.  With a rectangular field, do you cut your "end zones" and then cut the swaths side-by-side?  By cutting the swaths side-by-side, you would have your tractor in uncut hay on one swath and in the cut hay on the return pass.
Am I understanding this correctly?
I really appreciate you patience.
Mike NEIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike NEIN Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 6:31am
No, you still cut the whole field in circles no matter what shape it is. Once you start mowing you shouldn't have to raise the mower up until the field is finished. Except when you turn around to mow the outside round when you start.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2016 at 7:14am
Ditto what Mike just said. Just go around and around. On your first round, you will be hugging the left edge of the field, and running on uncut hay. Once you've made the first round, your tractor will be running on what you just cut. At some point, you will go around the field "backwards" (counterclockwise, steering to the left) to cut that outside round. This way, the only driven on hay you will be cutting is that outside round. It doesn't cut the driven on hay the best, so you wouldn't want to go back and forth and keep driving on hay.
They do make mowers that swing from side to side quickly and easily with hydraulics. It will trail the tractor to the left or right, so you can go back and forth without running on hay. If you have seen field mowed with that pattern and wonder why we're telling you different, it is because they had a different type of mower than you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jul 2016 at 10:56pm
Got it.  Thanks all!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 12:02am
So, I put up more hay this year and never could get a good grasp on turning the tractor with the pull type swather.  Many of you said I could make very tight turns if I went to the left.  I cannot make this work.  But, I also think I now know why.  I think my drawbar is too short.  Where I connect the swather and pin it, is in front of the rear portion of the tires.  As a result, if I make tight turns I end up hitting the tongue of the swather on the rear of the rear tires.  Does this make sense?  Do I need to get a longer draw bar so pin connection is completely behind the tires?  As always, thanks in advance.
See the pics of my current setup.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 2:02am
Whoever decided to put the jack on that side wasn't thinking that's for sure.As for cutting
some thought needs to be put into how the field rakes and bales the best.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 4:36am
pull that jack off if you can, if not swing it the other way.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 5:37am
Robin
Here is a Video that might give you some ideas about haying.
Gary
https://www.youtube.com/watch?v=OjhZDddDaUU
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 7:34am
Best cornering mowers I have ever used are the ones with the offset axle like the
AC 82T and the NH 456.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 8:53am
Besides the jack I see a bracket that a center bearing carrier should be to make it two piece pto shaft system. That must make some noise when turning sharp. What's the tractor your using. Have to remember back when these equip were built the tractors where bigger. With same hp as your compact. If your turning to the point that your hitting the tung, I would say its sharp enough.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 7:07pm
If thatsa Kubota pulling the swather, it may have a 2 position drawbar.  Take the drawbar out, and see if it has another hole, that sets the drawbar, further back...Wink
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 7:57pm
Robinhood, I think that you may be having a terminology misunderstanding here. What you have there are not swing tongues that are designed to be swung back and forth for field operations. However, there are true swing tongues (none made by allis) for cutting hay that you can swing from one side of the tractor to the other for back and forth cutting and always having the tractor in the cut hay. Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 8:06pm
Tbone, Dave, and others on here are correct. Extending the drawbar away from the tractor will be a big help as well as moving the jack to the left side and positioning back farther. With practice you will be able to come to the end of a field, turn right with a little right brake sharp enough not hit the tongue of the equipment, and as someone said when you straighten back out to go across the field it should back up and start cutting again across the end of the field without stopping. Dad's AC 390 haybine does this well. If I could get the video on here you could see my 190XT and dad's 390 haybine in action, you would understand after seeing it done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rlrobinhood Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 10:26pm
Hi all,
As always, many thanks for all the comments.  So for clarification, I'm leaving the swather and baler  in the operation mode (not travel position) and leaving it there.  I'm not swinging it back and forth.
Also, I am pulling it with a Kubota and when I turn, the rear tires do hit the tongue.  I will look at the tractor and see if the draw bar has two positions.  I hope it does as I think this will solve many problems.  At the end of the video, it is obvious that the pin connection is clearly behind the rear tires.
Every year, things get better.  My baler worked flawlessly! The swather, well thats an entirely different story....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 4:54am
Another thing you can try is to use a 3 point hitch drawbar, between the lift arms, to pull the swather.  I don't recommend it on hills, but in flat areas, it should work fine...
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 6:41am
For standard 540 pto operation the drawbar hole is supposed to be 14 inches behind the pto shaft coming out of the tractor. It looks closer than that on the picture. Moving the drawbar back will help you to turn shorter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2017 at 10:13am
I was mowing hay last night and I thought about this post. I have a 13' newholland hydroswing and I pull it with the 8050. I start turning when the mower is about 10' (not quite the width of the mower) from the corner. As the tractor turns it pulls the mower to the end and and backs right up and starts cutting a full swath making a perfectly square corner. I really don't have to turn the tractor that sharp either. I thought about trying to take a video but that would have been a little too much going on at one time I'm afraid.
We used to pull a 488 newholland with a D17 and it worked the same way but you had to spin the steering wheel pretty quick. I actually think the big mower is a little easier to turn.   I think if you can get that drawbar lengthened out you will have better luck.
