Check it out! The 26 foot "Ultimate Drag"
Daniel Christensen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Topic: Check it out! The 26 foot "Ultimate Drag"
    Posted: 16 May 2010 at 11:24pm
It took me a couple days to make a frame to hook two drags (plus a little one for the middle) to one tractor. It takes forever to "drag" with one 12 foot harrow and a D17/D19, so I made this. [TUBE]D5Rx_w4y554[/TUBE] I'm using my 185, and believe me it's working it some even though these are old fashioned shallow rippers.
I think it's great. And it even went over well with Les Miserables
Edited by Daniel Christensen - 16 May 2010 at 11:27pm
CAx3, Bx2, G, D17x2, D14x2, D15, D19, 190XT, WC, WD-45, 185, Gleaner K.
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:49am
Nice looking drag, Daniel.
Leonard
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 8:02am
Nice rig. Looks like you are getting 'er done. Need is the mother of invention - you figured out a better way to meet you need - cool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 8:51am
Yeah I wish I had two 16 foot drags I'd make a 35 foot Ultimate Drag! That would be the best ever. I'd need the 190XT to pull it and probably some front weights; you'd be surprised at how much these darn things pull your front end up in the air cause they're so low. This is 26 feet (28 feet with overlap), it's 84 teeth in the ground; it works the 185.
JohnCinMd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCinMd Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:02am
Great job! The only problem is that you get done in half the time, cutting down on fun time with the AC tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 10:07am
Nope! Not at all. Because we always use two people to do it; we use two D17's, we almost never drag alone because it takes forever because we "double kidder" to cover the ground twice. So now it's just me and I lost the other person their job xD
I'm gonna try to post the picture again; it didn't work before; I know many images don't here:
Okay it shows the image here after I click okay; it's as here as it should be, but when I click post reply it shows up as a blue question mark box.
Okay there's a link to an image.
Edited by Daniel Christensen - 17 May 2010 at 10:11am
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 1:47pm
like job,here in the mid-west we call those field cultivators or quack diggers, a drag has bars that lay nearly flat in a frame with steel spikes that 'skim' along the soil
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 3:46pm
quack diggers? Is that because they're so shallow and light duty?
Max(ia) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Max(ia) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 3:58pm
We always called them a Springtooth Harrow..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 4:34pm
Yes, spring-tooth harrow is the right name. http://en.wikipedia.org/wiki/Spring-tooth_harrow C shaped teeth that flex a lot. The biggest "common size" or size I know of/have seen is a 16 foot (4 section) one. This one is 7 four foot sections but over lap so it's 26 feet wide. I've heard of people maybe chaining two together which would be quicker but not as good as having them loose and free to breath and flex like this.
"The Muck", Torrey farms Potter extension is 1200 acres of fertile muckland and they still use drags now and then last I knew, they had two 16 foot drags. Pretty old fashioned for a human vegetable crop farm!
ScooterBuck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ScooterBuck Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:42pm
Springtooth is what we always called it. It was always my job. Pulled a cullipacker behind. The old 45 I used is in the garage right now:)
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 12:10am
i have a "kent" springtooth harrow, when i'd plow in the fall i'd use the kent in the spring to level and firm the soil, really works good, but it's to old fashioned for some now a days. i could even put down pressure on it if i wasn't covering the tracks good enough. has transport wheels and folds for travel. if you had alot of trash in the field, it was a dump rake!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 10:41am
ScooterBuck; you pulled a cultipacker behind the drag? We always plow, cultipack/roll, then drag, then plant. If it's sod we disk between packing and dragging. But dragging is always the last thing we do to prepare the seedbed for planting. Oh, they do have wooden "floats" behind them that smooth it out a little but they certainly don't pack.
Goose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Goose Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 3:37pm
Man oh man, now that is what I call flat land. They don't call you "Flatlander," now do they? LOL
Thanks for the photos.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Daniel Christensen Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 3:59pm
Our land is not that flat! lol we're in the northeast in New York. It's not like the midwest or anything. I see the photo now it looks flat. That's interesting; must be the angle I took the photo. Here look at this:  http://farm5.static.flickr.com/4009/4529734174_32329fa723_b.jpg
This really shows how not flat it really is: http://farm3.static.flickr.com/2661/4079194537_06ac5f8a49_b.jpg
This page was generated in 0.073 seconds.
