my 37 wc puller, 400 cube motor
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Topic: my 37 wc puller, 400 cube motor
    Posted: 08 Jul 2016 at 6:18pm
Edited by Robacpuller - 01 Jan 2017 at 6:46pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 6:25pm
Rest of picks
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 10:05pm
WOW 400 cubic inches amazing luv the unstyled wc good luck with It
Zaddison View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zaddison Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2016 at 11:47pm
What kind of classes/divisions do you pull with that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 7:21am
3500 to 6000, I'm pulling tommorow in a 60000 farm class. 8 mph, but I don't go that fast, I will do about 5mph at 2500 rpms. Will b pulling against some big iron. Last year I got 8th out of 15 tractors. Not bad for a little wc. I would have done better but stood front up and I had 500 up front, this year I will put more up front. I don't pull that class very often but it is close to home. I usually pull 4000 to 5000 class. They laugh when I show up to pull against m's and 88 olives ect. But I kicked a few of them. It's fun
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 7:37am
Good to hear the beating up Ms and 88s most importantly is the having fun part good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jul 2016 at 7:40am
I am going to video the pull hopefully I can get it on this Web site or u tube.
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2016 at 8:56am
nice puller! i moved my seat to the middle about 5yrs ago,pulls straight now.go beat up on those jd's as well!
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 8:00am
What's done to arrive at 400 cubes?
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2016 at 8:10pm
I bored the block to 4.600 bore stroked the crank to 6 inches. Big block chev pistons, 8 inch 350 international rods. The head is stock wc but a lot of porting and polishing. Big block chev valves 192 intakes 160 exhaust. Intake is ported and polished to Mach head. The carb is from a D17, but I opened it up real big I made a new ventury 1.480. I run 20% over rpms. Cam is ground. I pulled on Sunday in 6000 lb. Class and I ran out of power, it was an 8 mph class Iran 5 mph, a lot of the tractors were 100 hp more than me. I got 8th out of 16.Not bad for a 110 hp wc. A lot of old timers gave me the thumbs up. I recorded it so if I get it figured out I will have it on this site. I did all the work myself, my friend bored the block. The crank is a Merfeld crank. I didn't have grind much off the block to get clerance using the 350 rods. It is D17 block and crank. I would like to start building these motors for people it was fun doing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2016 at 5:45pm
I got a video of my wc pulling at sauk ffa pull. To see it go to you tube and put in sauk pull 37 wc
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2016 at 7:56pm
Or, look at it right here.
[TUBE]-tza5TMXDN0[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2016 at 3:36pm
Thanks
joetom08 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote joetom08 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2016 at 9:28pm
Originally posted by Robacpuller Robacpuller wrote:
Thanks
I sent you a pm
