WD 45 three way switch |
Post Reply ![]() |
Steve Bright ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Martinsville, I Points: 2107 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Jul 2016 at 10:34am |
Just ordered online the 3 way start/light switch thru Steiner, Are they OK or did I waste my money? |
WF owner ![]() Orange Level ![]() Joined: 12 May 2013 Location: Bombay NY Points: 5028 |
I, personally, would rather replace the cutout (on the generator) with a regulator to avoid overcharging the battery, then replace the three way switch with a regular push/pull switch for the lights.
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8455 |
Me too. That's the way my B is. It still has the 3 position switch, but it only operates the lights now.
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
I've heard the repop switches leave very little room inside the original box and will short out if your not careful about installation.
DanD ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: WI Points: 856 |
I have taken several of those switches apart, cleaned them with WD-40 or a similar product and then put them back together and they function perfectly. If you have your old one, try that. Not a lot to go wrong in them except accumulate dirt for 60 or 70 years. Just check the resistor to make sure it's not burned out.
Steve in NJ ![]() Orange Level Access ![]() ![]() Joined: 12 Sep 2009 Location: Andover, NJ Points: 12002 |
We offer an exchange program on the round Delco style switch. A lot of our customer's told us those aftermarket switches that everyone sells do not fit well at all in the instrument boxes and they short out causing issues. Drop by our website for pricing on our OEM rebuilt switches.
Steve@B&B bb-customcircuits.com |
Rick ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Jonesburg,Mo. Points: 3698 |
The newer style switches don't fit well in the electrical boxes on the smaller tractors like the B/C/CA/IB or the Styled WC, since those boxes are smaller than the WD/WD45. The newer switches will work in the boxes of the WD/WD45 though, but can be a pain. Steve has what a person needs and does a great job! Rick
Charlie175 ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Shenandoah, VA Points: 6369 |
Yep they are tough to fit (B). I put in a piece of rubber against the housing to stop any shorts.
Charlie
'48 B, '51 CA, '56 WD45 '61 D17, '63 D12, '65 D10 , '68 One-Ninety XTD |
Post Reply ![]() |
