WC/WF shifter
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: WC/WF shifter
    Posted: 04 Jul 2016 at 8:08am
Any body ever fix the sloppy shifter on a WC?WF  ?   how do you get the shifter out ?  so far i can't
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
KenBWisc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KenBWisc Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 11:48am
Yes. I had mine totally a part and replaced everything I could. A massive job to get the detente' spring and balls in.Probably not worth it. The sloppy shifter is primarily due to the small pin in the hole in the side of the shifter tower. Remove the transmission top from the trans body. My memory is than  than stellar but you may need to remove the clip on the bottom of the shifter near the ball end of the shaft.
You may also be able to simply punch the small pin through he tower and let it drop out. Buy an oversized pin from of the listed vendors her and drive it in from the outside. In addition to the sloppy er my other issue of concern was the reverse lookout didn't engage when shifter out of reverse. After all my work it didn't change at all. Any ideas about what I missed here?
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 11:58am
I took a bunch of pictures of doing my 34 WC shifter.  I have them here:
It is the same shift lever mechanism on the styled type, the 34 was the only year with the 4 bolts to remove the rail set up though.  I also have pictures of the shifter on my RC which is the same as the styled WC/WF.
Edited by TomMN - 04 Jul 2016 at 12:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 9:12pm
But     ??????  and the pictures are great ,   how do you get that thing out ?   i am now thinking  unhook the reverse lever and turn it ?  to the n notch so the clip releases ?
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 11:59pm
Take the reverse rod loose so you can turn it. It has to rotate for the reverse latch to come off of it. There is a snap ring in the top of the tower that holds the shifter ball down preventing the shifter from coming out, it has to be removed. Make sure you catch the pieces for the reverse latch and then you can pull the shifter out. For the pin slot I welded my shifter back up and cleaned the groove out and made a oversized pin by grinding a grade 8 bolt square and carefully drilling and filing the tower hole out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 3:07pm
Thanks  guys  i got out out safely this morning and have sent it to  a michanist to be redone. Hope to have it back in by next week .
This page was generated in 0.176 seconds.
