190 crooked fan belt |
Post Reply |
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7304 |
Posted: 30 Jun 2016 at 9:52pm |
Am I missing something here? Put the water pump and fan assembly back on the engine and set up the alternator with the new belt. The fan pulley lines up nicely with the outer pulley on the crank, but the alternator lines up with the INNER pulley on the crank. Do I have the right pulley on my alternator? The alternator came with the tractor, but I suspect it may have been changed at some point in its life. Can someone give in an idea of what the correct alternator pulley looks like?
KY poorboy
Orange Level Joined: 16 Aug 2015 Location: West KY Points: 933 |
Would the outside of a double pulley align with your others? Just a thought.
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20192 |
Pulley goes on first, then the SPACER, then the fan. Use inside groove on crank pulley.
DSeries4
Thanks Doc, that makes sense. I should have looked up my old pics!
MACK
Orange Level Joined: 17 Nov 2009 Points: 7664 |
Or hub was not pressed on water pump far enough. MACK
Beirnesy
Orange Level Joined: 30 Jun 2012 Location: Mid Western Ont Points: 351 |
mine is pulley, spacer, fan, and belt on inside groove.
BTW paint looks awsome, would you share with us what brand of paint you are using.
Thanks |
1969 220,1967 190DXT,1968 190DXT, LGT's 710,,716
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
can shim the alternator
Stan IL&TN
Orange Level Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
Me thinks that this would not be acceptable at this juncture. |
1957 WD45 dad's first AC
1968 one-seventy 1956 F40 Ferguson |
Gerald J.
Orange Level Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
I used me vertical milling machine to cut slots in the bent steel alternator bracket to allow aligning the pulleys on my gas 4020.
Gerald J. |
DSeries4
Has 2 coats of AGCO corporate orange on top of 2 coats of grey primer. There is going to be a lot of touch up to do once I get this engine put back together! |
Post Reply | |
