Allis Chalmers 5020 not starting
Jcutler81 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers 5020 not starting
    Posted: 30 Jun 2016 at 4:05pm
Hello, me again. Seems I can't mow without hitting a snag here or there. Stopped to clean out the radiator grate since I was almost in the overheating range. She's been cranking perfectly fine, no problem, then I hop back on and nothing. Last time I had this problem the PTO was engaged and so I made sure it was off. Also, I checked to make sure the electric PTO for the belly mower is in the off position as well.
All it does is turn the key into the on position oil and alternator light up and then nothing, won't click over.
Edited by Jcutler81 - 30 Jun 2016 at 9:56pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jcutler81 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2016 at 9:57pm
Bad positive cable, fixed and working now.
This page was generated in 0.253 seconds.
