Will these weights fit a B?
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Topic: Will these weights fit a B?
    Posted: 23 Jun 2016 at 10:48am
http://stillwater.craigslist.org/grd/5641311090.html
It says they are D14 weights, but I've never seen any like them. Are they genuine A-C weights? If so, will they fit a B, too? Probably not, but I figured I'd ask.
Thanks!
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 1:38pm
Don't know how, no hole for the nut that holds the hub on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 1:47pm
I was looking on Brian Ahart's website at the weight page, and there is not one pictured that looks like these. Maybe they're not A-C. I too thought the lack of the hole in the middle was odd.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 1:50pm
D/14 weights were in 4 parts.
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 2:18pm
They look similar to my CA rear weights, but I do not think as heavy (thick) but if we knew the distance across to bolt holes they might CA or D-14. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 2:59pm
I called him and he said it's 10" across, bolt hole to bolt hole.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 3:06pm
That depends on who much work you wanna do on em Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 6:05pm
I think 8.3X24 rims use a 13" or so bolt hole spacing for the weights.  I know I could bolt up 140 farmall weights to my kubotas, by just using 7/16" bolts, steada 1/2" bolts...
Those weights might be case. color sometimes fades to look like AC orange...
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 7:29pm
Add dose say : Wheel weights used on an Allis Chalmers D14.
Did not say they where !
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jun 2016 at 12:50am
I measured and while the holes in the weights won't fit my wheel centers, couldn't you just drill new holes?
He said they're pretty heavy. Maybe 150 to 200 lbs each. He said he has to use his tractor to move them.
