U Engine #
51ACWD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51ACWD Quote  Post ReplyReply Direct Link To This Post Topic: U Engine #
    Posted: 21 Jun 2016 at 8:53pm
Does anybody know what a U engine # of UM or UMA7601G denotes it as?just wanting to know the year maybe, and to see what fuel it took. It's in a 1936 U serial #12343
everett048 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 1:31am
G for gas K for kerosene(distillit) hope that helps.
Edited by everett048 - 22 Jun 2016 at 1:32am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 7:11am
They used letters K,G,H, and B on the U engines. K meant distillate 3,000 feet or below altitude. G was distillate between 3,000 and 6,000 feet and gasoline above that. All the letters were dual fuel, but they had different engines to run the most efficient at different altitudes
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 11:39am
Sorry but i think you have that wrong G & K are fuel types,Engines also had a A after the G OR K to denote if it was high altitude pistons or not.Compression was designated by either 3 or 4 types of pistons 1 of them being flat top the others being dished to different measurements for the compression ratio.Where as the A & K motors the wrist pin was moved up or down the piston depending on fuel type,(different piston types)
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 12:07pm
Even though my engine has the duel fuel tank, and dual fuel manifold?
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 12:10pm
What I am reading on the engine is that the G code had a 4.7:1 compression ratio. Gasoline was to be used at 3000ft or below and distillate between 3000-6000 feet altitude
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 1:31pm
Do you have any references I can read up?im not finding much out about the U's and just want to do some reading
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 3:54pm
if it has the dual fuel tanks from new, it May have run on distillate with the exhaust in the middle and the K on the heat exchanger  on the top side it may also have had the low comp pistons as well hence the engine n,o ending with a K. The pistons may have been replaced at some point with gas pistons.According to my DEALERS parts book piston part no 211658 with a 5/32 cupped top has a comp ratio of as you say 4.7-1 but how do you know what pistons are fitted?it could have part no 211657 cupped to 3/4 deep  for kerosene.And i quote from the dealers parts book the letters UMA in a typical engine serial no such as UMA-25197K indicate that model of the engine while the letter K following the serial no indicates the the engine is equipped with pistons and other equipment necessary to use Kerosene as a fuel,If the letter G follows the serial no the engine is equipped to burn gas un quote.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 4:10pm
I would think a compression check could tell you what fuel you can burn in your engine .
Edited by CTuckerNWIL - 22 Jun 2016 at 4:23pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 4:11pm
Weird. I know my manifold has BOTH spots on to change where my exhaust is ran at. Just a circular plate to cover which one is not being used. I am just simply asking. The engine has a FAINT A at the end of "UM" then under it has 7601G.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 7:05pm
my UC has kerosene pistons and runs fine on gasoline with the plate flipped.actually (it's been a while) I think it outlets the exhaust at a different spot for gas and kereo
Edited by SteveM C/IL - 22 Jun 2016 at 7:07pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote 51ACWD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 8:50pm
Mine has a plate on the side exhaust outlet and the exhaust dumps out the front under the hood. Has a spot for the dual fuel tank in the hood but is a G code engine. Why would it have the spot for a starting tank but have the g code for gasoline? And the manifold is a dual fuel manifold
Post Options Post Options   Thanks (0) Thanks(0)   Quote everett048 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jun 2016 at 1:37am
Almost all the manifolds were dual fuel except for the very early ones the first dual fuel one,s had a removable plate that you could either have in the front to run on low grade fuel or in the centre with a front exhaust to run on gas,they then changed to the next type witch you the exhaust was in the center and you just turned the plate to either G at the top or K at the top depending on fuel.As for the G on your engine no reread my previous post it is explained in that,Also your hood having a starting tank fitted was it original to the tractor? or has it come from another U as yours was damaged ? there is probably no way of knowing for sure.
This page was generated in 0.046 seconds.
