292 gleaner governor problems
vmlb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vmlb Quote  Post ReplyReply Direct Link To This Post Topic: 292 gleaner governor problems
    Posted: 20 Jun 2016 at 2:29pm
I'm having problems with my F. It has the 292 GM engine. The governor pushes the rod over the center point in the carburetor. Is the governor bad?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 2:57pm
i dont know anything about that engine but most carbs have a stop at wide open.  you might check and see if yours is broken/bent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 4:12pm
With the engine off and hand throttle wide open, lengthen the governor link rod until the carb almost touches the stop pin and no more. Every time the governor belt gets tightened, you need to check this dimension. Be sure to oil up all pivot points of the governor linkage and even on the carb throttle shaft where the throttle cable connects to.
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 4:45pm
Make sure that the governor has the right amount of oil in the case. Side plug!
vmlb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vmlb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 5:27pm
Thanks for all the help. Oil is checked daily. Went and looked at the neighbors part machine, not once but twice. Still can't figure it out. Got a mechanic on the way. If he doesn't show, I was wondering if Cal could come and fix it. It's 4 miles south and one west of Woodbine. Bought it from the Knopp bros.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 7:59pm
boy you are close!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 10:10pm
A qt. Of two cycle oil in every tank of gas will help. Throttle shift will get tight in bearings causing linkage to move over center  spring  in stead of throttle  shaft.  MACK
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 9:59am
The carb stop pin that DrAllis mentions can break or simply wear thru. Mine did it.
If your govenor is pushing the throttle shaft, then it is working fine. Concentrate on the carb's throttle shaft linkage & I'm sure you'll find the issue. I'll try to post a picture when time allows.
vmlb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote vmlb Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jun 2016 at 10:50pm
The collar around the carburetor  shaft was loose. Got it fixed and got done with the harvest. I've been telling everyone that my combine was built in 74 when the price of wheat was $4 a bushel.
