Weak clutch 190XT, how to find out wich one? |
Dutchboy Johan
Joined: 14 Sep 2009 Location: Netherlands Points: 571 |
Topic: Weak clutch 190XT, how to find out wich one?Posted: 15 May 2010 at 9:23am |
A few months ago i posted this also but i can't find it anymore. It was on the old forum.
One of my clutch'es from my 190XT is weak. But how can you find out wich one it is?
I've read something about activate the pto and put them in 8th gear and hold it on the brake's. I would like to know how i can see wich of the clutches is bad. i also find out that the left rear wheel will pull harder then right when i hold the brakes on it. The brakes are even strong on both side.
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands Allis-Chalmers 190XT Ser.III #26829XTD |
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3556 |
Posted: 15 May 2010 at 11:14am |
slip the clutch, if the pto stops it is the foot clutch , if the pto keeps turning it is the power director - check low range and high range
Dutchboy Johan
Posted: 16 May 2010 at 6:12am |
Thanks for it. I will find out wich one it is.
And futher, when i will overhaul the clutch. Is it better to buy a stronger clutch from a 7000 series or can i use also a clutch of a 200?
DrAllis
Posted: 16 May 2010 at 7:57am |
Foot clutch parts are the same. If you need discs in the PowerDirector clutch, use discs from a maroon 7000 (pn 70261212 I think)....they will never break in pieces like the old ones. |
Dutchboy Johan
Posted: 16 May 2010 at 1:07pm |
And because I live in the Netherlands as you know, i'm not an expert where i can find these parts.
Is this still available by Agco dealers and what will it cost?
