B front axle weight's FS
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Topic: B front axle weight's FS
    Posted: 15 May 2010 at 7:13am
Front axle weights .YES this weight will work on the adjustable front axle (later axle),witch is what it off of ,set up the way it is. You ahve to change the weights on the plate and need J bolts for the wish bone axle.I DO NOT have the J bolts.
$200.oo pick up only .May be able to have hauling from here Hanover Pa. 17331  to MN.
   As always OPINION's  & COMMENTS WELCOME
                                 Thanks             PM or call 717-451-6590
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 7:33am
Tony.Or View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tony.Or Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 1:07pm
 Hey  Fred !!    If you need  J-bolts  I have new  repros  in stock.   Tony
