226 Oil Pressure?
Gary(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Topic: 226 Oil Pressure?
    Posted: 19 Jun 2016 at 5:07pm
Guys I have a 226 that has been running great oil pressure and now after setting thru winter and spring it has no oil pressure. Any idea's on what could be wrong?   I  took gauge off and started and ran for short time and no oil out of gauge hole.  TIF Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 10:23pm
Take the filter off, pull stem out, file two V slots across bottom of stem then try if. Might crank it with stem out first.    MACK
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 11:13pm
So what tractor are we talking?  WD45 or early D17 with bypass system or newer 226 with full flow system?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 7:08am
It is a 226 with full flow system,sorry I didn't provide enough info on first post. Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 7:31am
If it is full flow, disregard what I said.    MACK
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 8:37am
This might work, remove the lower line coming out of the block that go's to the oil filter housing (the back line next to the block) and pump some new oil into it, might need to do it two or three times and install the line back on and try that before you go inside. Might be the oil pump gear to camshaft, relief valve, gears inside the pump, pump cover gasket bad, the list of what if is all just a best guess if looking from the outside in. sorry
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 8:37am
Full flow would be bad. That's mean the engine is possibly get no oil at all. I'd crack one of the lines and run just for a second and see if you have oil pumping. If not, something flew apart in your pump, if yes, check your filter and base because it must be plugged somewhere.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 1:30pm
Thanks for the idea's. I will try these before I pull pan. Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 2:24pm
I have a pre lube tank I got from O'Reilly when I bought a long block from them years ago. It was one of those buy it, use it, return it and get your money back deals they have on tools. I used it several times in 1 week so I just kept it and found another use for it.
Anyway, fill it with oil and use it to prime the system through the oil pressure gauge port. If it takes of and has oil pressure again, maybe all that happened is it lost prime. If it doesn't, it needs opened up and figure out what went wrong.
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 3:05pm
As others have kinda said, just go down the line in the oiling system and see where you begin to have problems. Don't run it anymore the full flow will completely starve engine of oil if clogged unlike the bypass system. You should have a good 30 lbs of pressure there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 10:15pm
I'd pull the plugs and spin it with the starter trying to get pressure figured out.
This page was generated in 0.056 seconds.
