deck spindle
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Topic: deck spindle
    Posted: 19 Jun 2016 at 12:54pm
Hi Guys; I have a friend with a "Big Ten" and he still cuts a small lawn with it. Bearings in one of the spindle have failed so now what? Anyone have NOS spindles? Is there another brand that will fit? Sounds like the shaft is bad also so rebuild would require machine shop work, thanks for any help you all may have    Mark
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jun 2016 at 8:50pm
These are pretty common parts. Is it the center spindle or an outer one?
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 6:13am
I'll have to ask him, is the center one different?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jun 2016 at 9:10pm
The housing is the same on the center but it has a taller shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 7:31am
It is one of the outside spindles that has bad bearings, are they rebuildable?
BillinAlberta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BillinAlberta Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2016 at 10:20pm
   Yes they can be refurbished.I found the bearings and shaft for my homesteader deck and 917 deck at the local AGCO dealer.
   The bearings look pretty standard so you should be able to get replacements at any reputable bearing shop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2016 at 5:07pm
6204 seems to be the common spindle bearing in just about every mower - I have went to shield and sealed bearing - using a metal shield on the blade side rather than just the plastic and seal used on the 6204RS bearing
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2016 at 3:40pm
I patched a spindle one time by wrapping some thin copper around where it was worn to fill it out and fitted a new bearing on it as tight as I could. Surprised me. Wore the deck out.
LionelinKY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LionelinKY Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jul 2016 at 1:43am
It would take ALOT of abuse to damage the shaft. Most likely just needs a new set of bearings. I say set because I would highly recommend doing all 3 spindles at the same time. Each spindle takes 2 bearings. Quite easy to do. Sandy Lake Imp has the bearings. I redid the whole deck for my B110 last winter. HTH.
This page was generated in 0.266 seconds.
