712h only runs with full choke when PTO is on |
Seth Souerdike
Joined: 22 Nov 2011 Location: Cutler Indiana Points: 4113 |
Topic: 712h only runs with full choke when PTO is onPosted: 18 Jun 2016 at 3:24pm |
So our 712h when mowing (PTO engaged) will only run when the choke is left wide open. Other than that it's fine. Any ideas?
There are no atheist in foxholes.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 21 Jun 2016 at 9:47pm |
Plugged air filter?
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4078 |
Posted: 23 Jun 2016 at 9:47am |
carb needs cleaned real well
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Posted: 23 Jun 2016 at 1:06pm |
Yeah, I'm wit' Hud on dat one. You have dirt or varnish pluggin' up the enrichment nozzle making the engine run real lean. Pullin' the choke closed most of the way fattens the mix, and cut off the air charge. Time to "rooto rooter" the Carbatrator....
Seth Souerdike
Posted: 23 Jun 2016 at 9:10pm |
I'd just as soon by a new carb, know where to get one?
HudCo
Posted: 24 Jun 2016 at 10:53pm |
still buy new ones from kohler we have ordered a few in for some of our customers but i would put new throttle shafts in and bushings if needed and re biuld it all the parts are available
427435
Joined: 18 Nov 2010 Location: SE Minnesota Points: 18637 |
Posted: 08 Jul 2016 at 10:45am |
You might try running some Sea Foam through it. There are full load mixture adjustments on my gas garden tractors, also. Run it all the way in to get rid of anything that might be in the orifice and then back out to where it was. If still won't run well, back it out some more.
Edited by 427435 - 08 Jul 2016 at 10:46am |
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel, GTH-L Simplicity Ignorance is curable-----stupidity is not. |
