WD45 Diesel Injection Pump
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Topic: WD45 Diesel Injection Pump
    Posted: 17 Jun 2016 at 8:04pm
I have an injector pump problem with my WD45D.  Original problem was that diesel leaked into the crankcase.  I had the pump repaired locally and it came back not timed correctly.  Took the pump back to the repair shop and when it was picked up and installed, it leaked on the outside.  Took it back to the repair shop and they said an o-ring was cut.  Just had it installed again after getting it back from the shop and the tractor runs awfully.  I am afraid that the repair shop has damaged the pump.  I am not taking the pump back that shop again.   Does anyone know of a dependable repair shop that specializes in repair of these old pumps and especially one that tests the pumps after the repairs are made.
ToddnwIl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ToddnwIl Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jun 2016 at 9:56pm
injpumped is your man. He runs his own fuel injection service. I'm sure he can help you out.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2016 at 10:00am
thanks todd for the plug, but PSB pumps are not my forte! I've got one here I'm looking for parts for. I'm looking for a rebuildable core, since I need a good hydraulic head. I really hate it when guys drag these things out of long term storage, and then just start cranking, or pulling them trying to start them. By then the damage is already done! There are NO parts available new anymore, and finding good used ones are very, very difficult.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jun 2016 at 3:32pm
Here's where I get my PSB-pump (WD45 Diesel) work done at. It will not be cheep but she will work right.
https://taylordiesel.com/contact-us/
Forgot to say; that you might check the lift pump seal and shaft for a groove cut into it for the Diesel leaks into the crankcase.
Edited by Don(MO) - 18 Jun 2016 at 3:38pm
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 5:44am
Might want to check with this guy Al Baker 231-757-0064.
marion View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote marion Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 7:28am
I had taylor diesel do mine also about 10 years ago
also good place for truck diesel work
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jun 2016 at 8:51am
Taylor Diesel in North Little RockAr. been doing pumps and injectors probably 50 yrs. always got good repairs from them. Leon
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jun 2016 at 9:55pm
the turbo shop in Blanchard Louisiana has overhauled 4 of mine and done a fine job.jim worked at Vaughn and busch in shv.for 35 years and he knows the old psb pumps.....
