HD11F LAND CLEARING |
R.KYLE
Topic: HD11F LAND CLEARINGPosted: 14 Jun 2016 at 8:45pm |
JUIST ACOUPLE OF PICTURES OF NEW TO ME OF RAKE FITTED TO MY TRACTOR AND NEW TO ME ROME PLOW. CLEARING FIELDS OF BUSHES I HOPE. ANYONE WITH AXPERINCE COMENTS APPRECIATED, MY FIRST TRY.
Josh H
Joined: 24 Feb 2015 Location: Carnesville, GA Points: 128 |
Posted: 14 Jun 2016 at 8:52pm |
Thanks for sharing! Where did you get the rake?
HD6GTOM
Posted: 14 Jun 2016 at 10:18pm |
Chrome stacker, always liked to hear them sitting there idleing. Good looking older dozer.
LeonR2013
Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Posted: 15 Jun 2016 at 7:13am |
Man, you're right. That is a good looking piece of equipment. With good care and not beating it, you've got years and years of economical use in that machine!
R.KYLE
Posted: 15 Jun 2016 at 8:35pm |
JOSH I JUST KEPT ASKING PEOPLE I MET IF THRY NEW OF A RAKE. A FRIEND SAID HE THOUGHT HE NEW OF ONE IN THE BUSHES AFRIEND OF HIS USED TO USE. IN THE END IT WAS A5 HR DRIVE EACH WAY AND ALOT OF REBUILDING BUT I HAVE A RAKE.
Josh H
Posted: 15 Jun 2016 at 10:36pm |
That's cool. stuff like that's a rare find. If i acquire
A 16b or 21b it would be cool to have allis clearing Blade for it, as well as rake. |
AC Mel
Posted: 15 Jun 2016 at 10:53pm |
Roy, post up some more pictures. That 11F designation should probably been for a pipelayer sideboom tractor. I can see that it has the long swing frames and is it a rigid frame? Also can see that the blade trunions are mounted farther forward to accommodate the long track frames. Looks like the battery box was the side boom type also. If so the hydraulic hardnose with blade cylinders was added later. Pretty cool tractor. It's safe to say no brush will be safe around you with that setup! More pictures as you go.
HD6 Merv
Silver Level Access
Joined: 03 Aug 2010 Location: New Zealand Points: 498 |
Posted: 16 Jun 2016 at 3:50am |
shes a very early 11 too. Manuel steering clutchs with long levers.
Be Buda power too unless it had a transplant at some time |
tits tyres and tracks
they all cost you money |
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1002 |
Posted: 16 Jun 2016 at 5:17am |
Merv
Have a look around the intake manifold. That looks like injection pipes which ought to say Buda? |
Ian Beale
Posted: 16 Jun 2016 at 5:23am |
Or, after a look at an 10000 parts book and another look mightn't as those between #3 and #4 seem to be heading up. And it has the integrated fuel filter assembly.
donoman
Joined: 18 Feb 2015 Location: New Zealand Points: 117 |
Posted: 16 Jun 2016 at 1:51pm |
10000 motor
R.KYLE
Posted: 16 Jun 2016 at 9:43pm |
YES MEL IT IS RIGID FRAME AND YES TRUNIONS ARE FARTHER FORWARD PUSH ARMS ARE SHOTER AND BLADE SETS OUT A LITTLE FARTHER IN FRONT OF TRACTOR. DONOMAN ENGINE IS NEWER. I DONT KNOW THE DIFFERENCE BETWEEN A 10000 AND 11000 ENGINE. THIS ONE HAS TURBO AND INJECTERS ON TOP OF HEAD.
Ian Beale
Posted: 17 Jun 2016 at 12:11am |
11000 then
R.KYLE
Posted: 07 Nov 2016 at 7:51pm |
HY GYS SOME PICTURES OF THE HD11 LAND CLEARING THIS SUMMER. VERY PLEASED WITH ROME PLOW IN ALDER BUSHES. REALY ROLLS THEM OUT BY ROOTS ALSO PLEASED WITH RAKE WORKS WELL. THE WINCH HAS 10 CHOCKERS AND HANDLES THE LOAD EASILY. AL IN AL EVERY THING WORKED WELL. TRACTOR COULD HAVE BETTER WITH SOME SCREENING AROUND CAB. A LOT OF BUSHES IN THE FACE.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88888 |
Posted: 07 Nov 2016 at 8:10pm |
NICE TRACTOR !!
Tennessee Plowboy
Joined: 19 Aug 2015 Location: Auckland NZ Points: 8 |
Posted: 10 Nov 2016 at 2:12am |
I used to sell Rome Equipment export and domestic. That's a great disk you have for your job. None better on earth. Looks like a TMR-10-28. I know a guy in Rockmart Ga. Who can supply disks, bearings or any part needed at wholesale prices. Nice arrangement. I'm working on a landclearing machine myself. A HD11E with a Rockland V-blade. My tractor will be re-powered with Detroit 6v72t , installed but not started up yet. I'll be looking for a disk like yours at some point. Happy clearing ! |
BrianC
Joined: 16 Jun 2011 Location: New York Points: 1619 |
Posted: 11 Nov 2016 at 7:08am |
Rome spec sheet:
http://www.romeplow.com/images/Standard%20Rome/Primary%20Tillage/TMR.pdf It needs 7500 pound draw bar pull from the tractor. With 400 pounds weight per disk, does it slice up brush and roots? |
Tennessee Plowboy
Posted: 11 Nov 2016 at 1:09pm |
This disk harrow is known as a bush and bog style harrow and is very well suited to the heavy application you are using it for. The discs appear to be well worn and the effectiveness will be greatly improved with a new set of 28"x 3/8 cutout disk blades.
Chopping cleared ground with this thing will result in a much faster clean up by speeding up the rotting of roots and stumps. The Rome spec sheet can be viewed at this link: http://www.romeplow.com/images/Standard%20Rome/Primary%20Tillage/TMR.pdf |
