718 hydro
AC puller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Topic: 718 hydro
    Posted: 13 Jun 2016 at 5:06pm
So what makes the hydro rearend not move when u start it up untill i rev it up?
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 8:38am
Most commonly, slipping drive belt or low fluid.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 9:18am
First thing I would do is a fluid change and go from there. Like TMG said, might be low on fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC puller Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 7:33pm
I restored this tractor a few years ago.All new but rearend.Had broken axel when i got it and no fluid. Sat for a few years before i got it.It always worked but would slow down on a grade then speed up going down.Been slowly getting worse.Last few months when i start it it will sit there and not move till i rev it up. Other day started up and took a good 5 minutes to get it to move. Changed fluid this spring and filter. Fill tube set to the book.Right amount of fluid.To the book.Definatly not the belt.Is there a valve that could be sticking?
This page was generated in 0.177 seconds.
