B212 backfire |
NATHAN CAIRNS
Joined: 07 Feb 2016 Location: Brighton IL Points: 104 |
Topic: B212 backfirePosted: 12 Jun 2016 at 1:12pm |
I was running my b212 today and it was 100 degrees and I was trying to run some gas out of it since I don't run it much. I ran it almost wide open and about ten minutes later I idled it and it started backfiring every five seconds or so. It didn't do that when I started it
B212, WD45, B, 912 Hydro
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4077 |
Posted: 12 Jun 2016 at 4:46pm |
probley some water in the bowl
NATHAN CAIRNS
Posted: 12 Jun 2016 at 5:54pm |
It has always been in the garage though and what is the bowl. Is that the carb
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2584 |
Posted: 13 Jun 2016 at 5:44am |
There is (or should be) a sediment bowl under the fuel tank. You'd need to remove the left side panel to see it. May have gotten enough condensation in the bowl that it got some down to the carb. Easy enough to remove and dump out.
AaronSEIA |
HudCo
Posted: 13 Jun 2016 at 10:05pm |
float bowl on the carb just needs one drop of water to foul the main jet dosnt take much to get condensate
