Rod and piston combination
bigcountrykustoms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcountrykustoms Quote  Post ReplyReply Direct Link To This Post Topic: Rod and piston combination
    Posted: 11 Jun 2016 at 8:47am
I've got a late d-17 block with 4.5 inch bore and 5 inch stroke. If you've got the same displacement what did you do for a rod and piston combination? I'm in desperate need of knowing so I can let hapco know what I'm using before he welds my crank. Thanks much for any insights
mike a View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mike a Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 11:22am
hope marty chimes in on this one
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 12:56pm
i used a 427'GM piston' W\ ac 190 XT rods bearing over bearing on crank' runs strong put together 8 years ago'
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 5:13pm
do you have 5" or 6" stroke i thought fred's old engine was 6" if your going 5" i used  d19 rods
Edited by patrickmull - 11 Jun 2016 at 5:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 11:23pm
the d19's will work on 6'' crank' like pat' said
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 12:09am
So if hapco is welding the crank, it's the same amount of work to do it weather the stroke length is 5" or something else. But I've used billet rods I have a friend make, farmall h&350 rods and Chrysler rods. If I were doing it and not wanting to spend money on billets, I would use the Chrysler rods.
The buda rods people like to use are just plain short and would require a tall odd piston, and to short for a decent rod to stroke ratio in a longer stroke engine. They are great in some situations depending on what other parts you're trying to use but for this they wouldn't be a first choice.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 12:12am
Depending on the rod used, it's also nice to lay the crank and cam out and mark & measure so the journals get positioned between the cam lobes if the rod is going to be wide enough to interfere with the cam lobes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 10:15am
What Chrysler rods would someone be looking for? I should have some 440 6pack rods somewhere.
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2016 at 8:52pm
I used lnternational 350 rods, 6 inch stroke, 4.600 bore, big block Chevy piston 1.24 piston height. Merfeld did my cranke, he narrowed the rods. 9 years ago and still no problems. But I only run about 1800 rpms to 2000.
wi50 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wi50 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 9:41am
I've got a bunch of the rods around and vintage power wagon is an outfit that sells chrystler parts and has them on hand, 218,230,237,251 engines used connecting rods that used a 2.062" crankpin diameter and they were 7 13/16, 7 7/8, 7 15/15 and 8" lengths available.  There's left and right offset rods as they have a slight offset of the beam to bearing bore.  The wrist pin end is small, easy to hone to a .927" pin bore or I bore them in the mill with a reamer to get a .990" pin size.  The rod bolts are 3/8" and easy to use an ARP bolt from a BBC application.
Depending on your block these rods will clear fairly well.  Lots of common automotive pistons available and with these rod lengths it's easy to come up with a combination of cheap and available parts.
Edited by wi50 - 14 Jun 2016 at 9:44am
Larry(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2016 at 1:57pm
I take it those are the old flat head engines? Just found a stash of them a guy is selling off:) One says Turbofire )i think it was) on the head
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact*
I can explain it to you, BUT I cannot understand it for you!!
This page was generated in 0.104 seconds.
