Early wide front for the WD |
David Maddux
Topic: Early wide front for the WDPosted: 14 May 2010 at 8:36am |
Michael Crow was over yesterday, he looked at the wide front I have been rebuilding this winter, and noticed it was for the early WD's. It has the front square tube that is two pieces welded together across the length. What I am wondering, is what serial no. tractors could this wide front be correct for? I was going to put it on a 55 WD45, but now it don't look like it will be correct for this tractor. You learn sometimes slowly. Dave.
RichinWis
Joined: 11 Sep 2009 Location: Deforest Wis Points: 691 |
Posted: 14 May 2010 at 8:50pm |
David, that front would be for a very early WD 3 bolt front end and also correct for the last of the WC's. I know that many 3bolts were fitted with the one piece center piece before the 4 bolt came along. I would certainly not put it on a 45 if I wanted it to be correct. I don't think the parts book differentiates between the center pieces
Sandknob
Joined: 12 Sep 2009 Location: Oblong, IL Points: 2456 |
Posted: 14 May 2010 at 8:53pm |
I believe you would need the late three bolt then or a four bolt. I may have a 54 three bolt for sale (I will know by tommorrow).
Adam
David Maddux
Posted: 14 May 2010 at 9:01pm |
What a drag, I disassembles everything and built up every piece and had it turned down, along with new bushings. I guess I will need another tractor now. Oh well all I need then is an early serial number transmission and a WD motor.
David Maddux
Posted: 14 May 2010 at 9:04pm |
I have a WD, so I guess I still need to know what serial numbers will be right for this front end.
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 15 May 2010 at 7:48am |
Dave, If I looked it up right (out of a old parts book I have) a WD with S/N 59987 and before will be the right tractor for your front end.
Don
David Maddux
Posted: 15 May 2010 at 8:12am |
I gave it some thought over the night,[didn't really loose any sleep], but on a fully restored 45, I think I will go ahead and use that front end. What the heck, it isn't going to be worth anything anyway, so what value will be hurt if it has the wrong front end? I put a lot of work into this project so far. It would be a different story if there were less than a million made. I don't think I have ever seen a really nice restored WD45 sell for anything more than 3500.00 anyway. I will have way more money and time in this than it is worth. It is like when I restored my D-14. It was my first tractor restoration project, and was trying to find out what color it needed to be. All the books I read said that persion orange 2 started at year 1960. What the book failed to tell me was that it was when the 14 ended and the 15 started. So My D-14 is painted the wrong color. I didn't change it, because it looked just fine for tractor drives and such. We all live and learn. You would think as much as I am supposed to know about this stuff by now I would do the research and get things right. Still learning, Dave.
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 15 May 2010 at 11:23am |
Dave it is RIGHT,RIGHT for you .Do'nt worry about the CRYBABY's that cry about how you do things ,you payed for it.
Michael V (NM)
Posted: 15 May 2010 at 11:55am |
yea,kinda like what Fred said.....anyone really gives you trouble,tell them it was that way when you got it....
GBACBFan
Joined: 11 Sep 2009 Location: Green Bay WI Points: 2662 |
Posted: 15 May 2010 at 12:13pm |
If it's well done, looks good, runs out great, and you like it, at the end of the day, that's all that matters. Having seen your work, I know it would be a piece I'd like to own whatever you do to it.
are genuine." - Mark Twain |
RichinWis
Posted: 15 May 2010 at 12:14pm |
Dave, the only thing different is the center section, that is easily changed anyway if you wanted to.
BobHnwO
Joined: 16 Sep 2009 Location: Jenera Ohio Points: 693 |
Posted: 15 May 2010 at 12:18pm |
Like the guys that kept naggin about my D17D Series 3 decals were on backwards,so I took them off!
Brian G. NY
Posted: 16 May 2010 at 8:04am |
RichinWisc,
I had never before heard that the very late WCs used that style WFE; Interesting
piece of info.
DrAllis
Posted: 16 May 2010 at 8:21am |
I'm not so sure you couldn't "grind" the weld seam away and use "Bondo" and heavy primer on the top of that axle tube and hide the fact that it was the older one.
