616/620/720 mower deck question
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 616/620/720 mower deck question
    Posted: 08 Jun 2016 at 8:11am
on my deck, one of the adjusting handles actually moves freely when i'm mowing,  the spring appears to be intact but i have not disassembled it.  do you guys think it's the spring or something else?
Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 10:25am
are you referring to the adjusting handles for the rear rollers?  If so, there is no spring  for them.  Can you clarify or give a picture of what you are looking at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 10:40am
yes the height adjusting handles.  what is the function of the spring on the shift under the t-handle?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 11:05am
The spring is there to hold tension on adjusting screw. Vibration of deck will turn them with tension over time. If spring is weak, adjust it where you like, put a jamb nut on bottom. That will fix the problem. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 11:56am
Looking at the parts diagram for the rollers and T handles - no springs anywhere.  It does show a jam nut though.  Can't get the picture to display here.
Here is a picture of mine...
Edited by DSeries4 - 08 Jun 2016 at 12:00pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jun 2016 at 1:03pm
 There were two styles of adjustments on those. I have both kinds. My unmolested pristine deck has springs, the others don't. I think the lenght of tube was shorter on the ones with springs. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jun 2016 at 7:42am
tracy is right, thanks for the advice tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 8:37am
Another one of those little items that are overlooked. These Tractors have so many little subtle differences, it makes ya scratch yer' head till yer' bald! If it ain't wiring, its switches, or routing. Now its mower decks. Sheesh! And, btw, the center of my head is getting pretty shiny up there.... LOL!
This page was generated in 1.957 seconds.
