Kohler M20 ?
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Topic: Kohler M20 ?
    Posted: 07 Jun 2016 at 7:13pm
What will cause this engine to surge/ pulsate under load   with tractor and mower 48:"
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 8:42am
Bad spark plugs or wrong heat range, lean condition, dirt in the enrichment circuit, (which causes the lean condition) dusty, dirty partially clogged air filter. There's a few for starters. Check the easy stuff first. That's usually what it is....  HTH
eslickl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eslickl Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2016 at 5:59pm
I  had similar prob. First mine would stumble and back fire under load after running for 3 minutes, I finally blew into the fuel cell thru the fuel line and that fixed that. (something plugging the fuel out let in the tank)  Then I had a prob with running at wide open throttle with load. I have gone thru the carb and lowered the float, just a little and that has seemed to taken care of that. Have since mowed a 5 acre yard with no prob.
These are just ideas, and they worked for me.
This page was generated in 0.115 seconds.
