D-10
timg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote timg Quote  Post ReplyReply Direct Link To This Post Topic: D-10
    Posted: 13 May 2010 at 8:34pm
What do yall think a 1963 D-10 with a busted block is worth? The rest of the tractor is in fair shape. I have a (i think) 1959 D-10 and thought that I might pick up the other tractor for parts. I can only see a few changes on the 1963 from the 1959. Will most of the parts work on my 1959 model?
Thanks
timg
DREAM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DREAM Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 8:46pm
Not an expert on the D-series, but wouldn't there be a series change from 1959 to 1963? Maybe series 2 to series 3? Somebody else will help, just bumping it up.
Walter(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walter(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 9:40pm
The Series II D 10 will have independent P.T.O. and a different hydralic pump.  Also the engine will be more cubic inches having the same H.P. as a D14.  The Series I will have the same H.P. as a CA  with a CA hydralic pump and P.T.O.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 11:15pm
Thinking out loud, not knowing the extent of the cracked block, the condition of the tractor, and knowing the relative rareness of the D10 (approx 2500 made); it may be worth the effort to rehab it. Have seen pretty badly cracked blocks fixed up with plastic steel. If the block is too far gone to be fixed up, a donor 149 or 160 engine will bolt right in. Not for sure, however, but would suspect that the 125 would also bolt in without much of a fuss. If it were closer and it is complete, I would offer $1500 for it and consider it to be a candidate for a rehab project.
This page was generated in 0.099 seconds.
