Different engine sound in 190XT´s ??
Dutchboy Johan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Topic: Different engine sound in 190XT´s ??
    Posted: 13 May 2010 at 3:15pm
Is it right, that you can have a different sound of the engine when you have both the same engine, like the diesel version?
I´ve seen some video´s from different XT, all diesels and i notice that there is a deviation in engine sound. Is that right? And if it is soi, how is that possible? Come´s that by the muffler?
I´ve seen XT that you hear the turbo wistle, but also XT where it is more like a ROAARRR like a V8 or so.
Thanks.
---> Better by Design <---
Johan Straver, Almkerk/ Netherlands
Allis-Chalmers 190XT Ser.III #26829XTD
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 3:56pm
different turbo's were used over the years, as well as injection pumps with and without automatic timing advance. All these things can make them sound different. Also, audio sounds can be inconsistent. Ed.
niel ev View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 3:57pm
Some of the diffence can come fromthe muffler and straight pipe also ther is some difference because of the different turbos that are used and then it is also probably the different house power out put the old ac mechanics had a habit of putting the screw to the pump and getting 120 horses out of the tractors Niel
Steve Wilson View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Wilson Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 10:19am
I put a new muffler on my 1968 190XT because the turbo whistle was so load and shrill above 1800 RPM that it caused me to use ear plugs.  With the new muffler I can't hardly hear the turbo anymore.  In fact, while it was later at the dealer's getting the injector pump and injectors rebuilt, I had them check out the turbo to see if it was still working properly.  No joke.
Steve Wilson
Mid Missouri
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 2:48pm
I will put an other muffler on my XT. Normal it is also a straight steel pipe but i would like to put a chrome curved pipe on it. Curious what difference in sound it will be.
I would like to give it a more a 'roaarr' sound
dhexom View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dhexom Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 3:09pm
Put an over size pipe on it and that will give it more of a roar. I did this on my D-21 and it certainly did help it.
Dean(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 7:21pm
My 2 cents worth, for what it's worth.
At about 7500 hours, some of the early 190XT tractors would have
the cam gear break off the end of the camshaft. The only part
available, was a 200 engine camshaft. It had different valve
timing and overlap and it sure didn't sound like an XT
after that. If you didn't explain it to the customer
before hand, he could get really excited.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dutchboy Johan Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 9:17am
Interesting to read all these story's. Thanks for it.
@ dhexom: What size of pipe did you use on you're D21?
Post Options Post Options   Thanks (0) Thanks(0)   Quote niel ev Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 9:58am
Johan when we restore a tractor we get a 3 inch that swells out to 4 inch just above the hood sure sounds good Niel
