WD spin out cams
brenpak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Topic: WD spin out cams
    Posted: 01 Jun 2016 at 11:58am
Has anyone thrown these cams into a bed of red hot coals and then took them out and they were loose? I just sprayed them but I read somewhere they loosened them up by throwing them into a fire? Sounds easier than beating them and spraying them? Im looking for input on the easiest way to loosen them up, I already have them off the center ready to start the process, Thank you
WD45Diesel57 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45Diesel57 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 12:13pm
dad and I threw them into a wood stove in the coals and pulled them out red hot and they turned easily and the rust falls out when turning them
1-B's, 2-C, 2-CA's,2-WF, 1-WC,1-G, 3-WD's, 2-WD45, 1-RC, 1-D17 Diesel, 1-D14, 2-D15,1-D17 row crop,1-D19 gas and All Crop 40,60,66,72,90 and 100
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 12:16pm
Excellent that is what I am going to do This weekend heat them up!
1953CA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1953CA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 12:59pm
worked mine with an impact gun...
1945 AllisCletrac / 1948 "B" / 1953 "CA" / 1955 "WD-45" / 1963 "D-15 Series II"
"No Air Support without Ground Support"
VFDfireman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote VFDfireman Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 1:54pm
I have found that electrolysis works wonders on seized up on the wheel eccentrics.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 8:57pm
Also did that with a set from a D14.  Left them in the air tight wood stove over night.  Things started to loosen up after that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jun 2016 at 9:22pm
I have loosened 24 of them but never tried putting them in the fire. I have used oxy/acct torch to get them red and then loosening the eccentric.
Good luck, they do get stuck tight!
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 12:26am
I would also try the wood stove method.
www.awtractor.com
A&W TRACTOR 920-598-1287
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 6:50am
I thought it was a lot easier (but maybe not as much fun ) by using the rose bud heat wrench like Chris did.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jun 2016 at 7:33am
I think it's time for weeny roast.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 4:17pm
If you have a Weber Kettle, just start it up with plenty of charcoal and throw them in it over night.  Works GREAT!!  I have done it several times.  I have a bunch I need to do one of these days.  Easiest and fastest way to do it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 4:23pm
I have got 8 out of 12 to work by pounding them back and forth in a vise
with pb blaster the other 4 im going to have to cook LOL! but the weber trick is an excellent idea.. I will give that a go as the other non respectful cams will not budge even after 3 days in pb blaster! Thank you so much for the ideas!!I will let you know the outcome..
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 4:30pm
Wow, I'm starting to feel really, really lucky.  The spin-outs on my WD haven't been used for more than 20 years.  A couple months ago I needed to move 1 wheel out about an inch for clearance on something.  I thought that this may be a BIG JOB.  I got a 1/2 inch drive socket and breaker bar and give it a try.  NO PROBLEM.  The spin-outs broke loose pretty easy and we moved the wheel and tightened them with very little trouble.  I was amazed.  After seeing this post, I'm feeling very lucky too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote brenpak Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 4:36pm
Hey I had to Ice down my shoulders after pounding and spraying these cams so yes count your blessings!! I believe my last resort is the weber method besides that frees up my hands to pour some drinks while it cooks LOL!!! Instead of flipping burgers I will be flipping cams..
Edited by brenpak - 06 Jun 2016 at 4:38pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jun 2016 at 5:14pm
AND, the better half won't pop a cork finding them in HER oven!
