55 wd45 dsl for sale new pics $3500
coop97 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Topic: 55 wd45 dsl for sale new pics $3500
    Posted: 13 May 2010 at 1:31pm
 Run great ,has been overhauled. Block has been cracked above generator.  Additional block  not cracked for $600 more.
Edited by coop97 - 01 Jun 2010 at 7:52am
56 WD45 DSL,55 WD45 DSL,53 WD45,50 G,48 C,37 A,30 E 25-40,28 E 20-35,79 5030
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 3:23pm
I guess no one is interested in a 45 dsl.
Bryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bryan Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 3:36pm
Where is it located?
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 3:38pm
Um, coop97 you posted your question mid-afternoon. Most of the guys who might help you are outside farming, off at work, etc. They're not sitting around inside waiting for questions to answer! I suggest you wait until tonight and see what happens. BTW, I have no idea what it's worth. Where are you located?
WC, CA, D14, WD45
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 3:40pm
I am located around Nashville, TN
skipwelte View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote skipwelte Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 4:04pm
What the heck,   Id say around a couple of thousand.  Lots of work there to bring it up the 5 thou range that everybody wants.  Cracked block doesnt help, overhauled engine is a plus,  hows the rear rims-look like they could be pretty thin, hows the trans-jump out of anything, hows the hyds work????    Id have ta hear it run before Id go higher.    HTH
Edited by skipwelte - 13 May 2010 at 4:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 9:08pm
A good, mechanically sound 45D with good tires would probably bring $5.5K here in Iowa.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 9:15pm
hydraulics work good,  Doesn't jump out of gear.  As for the rims they are all good except for left rear has some bad rust around the valve hole.
As for the crack here it is
allallis2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 9:48pm
looks to be in fair condition. So what are you thinking on a price? I had a price in my head, have to see if I'm close. Did have one question.... what is the c chanel bolted to the front for?  thanks for posting.
Edited by allallis2 - 13 May 2010 at 9:51pm
1955 G,1938 wc unstyled, 1938 A 1938 B, 1949 G
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 7:22am
No idea what the c channel is for.  That's the way i bought it.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 7:41am
Video of the tractor running
[TUBE]vRX-0ZagR8k[/TUBE]
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 11:06am
 You say your around Nashville ? Was this tractor in the flood ?
http://www.rumelyallis.com
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 12:25pm
No it was not in the flood.  Tractor came from 30mi SE of Nashville.  No flood damage here.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 1:11pm
how is the power steering?
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 1:39pm
It really depends on how much muscle you have. The tractor does not have power steering. 1955 serial 207187  it still has the single groove pulley on the crank and water pump.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 9:07pm
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 9:42pm
Updated
Luke R. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke R. Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 8:02am
This maybe a dumb question, but how many years ago was it overhauled and if so why wouldnt you change the filters?
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 9:32pm
The gentleman I purchased the tractor from indicated it was overhauled 10yrs ago.  It was brought back to his home and used once before he let the block freeze and bust.  He said it sat ever since.  I bought the tractor not running.  Pulled the pump off to make sure it was not stuck.    Put diesel in it and a bleed the injectors.  Fresh batt. and 3 turns with no ether and fired right up.  It does NOT have a miss when it first fires up.  Engine is very strong.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2010 at 10:10pm
Looks to me that the fuel line from the external pump goes directly into the injection pump, with both fuel filters bypassed. a rebuilt engine wont last long with uncleaned fuel going into it.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 7:32am
The primary filter is not bypassed.  The secondary and intermediate filters are not on the tractor.  I have located a new secondary canister filter but have not installed purchased it.  Trying to sell the tractor.
kendak View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kendak Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 8:30pm
waaaay to much....friend of mine just bought one running that looks better than that for $1250 ....has narrow front but runs sweet
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2010 at 9:13pm
Well your friend got one H of a deal! 45 diesels are pricey suckers!
corlewfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote corlewfarms Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2010 at 6:09pm
how much $$$$
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 19 May 2010 at 10:25pm
Originally posted by corlewfarms corlewfarms wrote:
how much $$$$
He's asking 4000. Wish I could do it but just not gunna happen.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 4:01pm
-bump
Post Options Post Options   Thanks (0) Thanks(0)   Quote kendak Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2010 at 7:26pm
45 diesel motors were a piece of crap when new ....overhauled 10yrs. ago WOW...we used WD-45 back in the 50's had [2] diesels & [3] LP's...could never keep the diesels in the field...i know of several diesels & a lot of gas tractors ...just ride around the east side of MS. in the hills & there are plenty sitting around...anywhere from $250 to $1200 for any of them...I use a 1956 WD-45 as my baby pulling tractor...take care
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2010 at 9:24pm
It also sat 10 yrs in a shed.
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote coop97 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:05am
I would stock up on the WD45 DSLs if they are that cheap.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allallis2 Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2010 at 9:48pm
that makes two of us, I've never seen a 45 dsl that cheap.
