got a 2312 simplicity that has a problem
Ronnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Topic: got a 2312 simplicity that has a problem
    Posted: 29 May 2016 at 5:50pm
It has a 16 up brigs on it.
Tractor runs great and has lots of power.
Now the problem when it gets hot it will all of a sudden when it's idleing and u go to move it just shuts off and will not restart in less u let it sit for bout 5 to 10 minutes then it will start up and run all day.
This is what I have done so far
New carb kit
New plug
Checked spark at time of no restart
Shoot eather some times works
Adjusted high idle
Adjusted low idle
Any outher sigestion please
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 10:56pm
check gas cap vent change fuel filter to briggs part 298090s the red one
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 6:56pm
adjust valves. Leon R  Cmo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 7:02pm
Gas cap is brand new from simplicty fuel filter is new as well.
It acts like it gets flooded but when I pull the plug its dry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 10:57pm
check valve lash
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ronnie Quote  Post ReplyReply Direct Link To This Post Posted: 31 May 2016 at 7:05am
What is the valve lash spec for both valves?
