8010 Radiator Foam
dpower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dpower Quote  Post ReplyReply Direct Link To This Post Topic: 8010 Radiator Foam
    Posted: 26 May 2016 at 4:46pm
Just curious if any place sells an aftermarket foam kit for the foam around the radiator on an 8010?? AGCO has it just curious if anyone else sells this kit. Thanks
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 5:47pm
yes...I've seen it somewhere
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 5:50pm
Don't know about the "kit", but I bought the material from McMaster-Carr to do my 220 radiator. I had bought the kit from AGCO for my 190 and it consisted of what looked like carpet padding pieces glued together. So when the time came to do the 220, I didn't even go to AGCO. The foam sheets you buy at McMaster come in different thicknesses and softness. I would go for the softest grade. It also was black which I liked a lot better than the multi colored pieces glued together.
JCFarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JCFarms Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 9:19pm
I used the foam I pulled out of the old seat I removed from my 8010. Cut it to the thickness I needed and stuffed it in. Been like that over a year now. Works great!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 9:55pm
Closed cell would work best. It will hold less moisture. JMHO, Tracy
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2016 at 11:35pm
I bought some window air conditioner foam from the local hardware store for stuffing the gaps around the opening. It was about 3" square and 2' long to use on my 7060.
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2016 at 5:44am
I bought foam from Walmart and some spray adhesive. I think it cost me around $14. Cut the foam glued it together and STUFFED it in there. It is tight. Worked good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2016 at 5:47am
Forgot to mention it was a 190xtd that I was working on, don't know if that makes a difference.
This page was generated in 0.441 seconds.
