Changing narrow to wide front
rossinmich View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rossinmich Quote  Post ReplyReply Direct Link To This Post Topic: Changing narrow to wide front
    Posted: 12 May 2010 at 9:52pm
Thinking of changing one of my wd's to wide front. Have a narrow front on it now, and know of a wide front available. What all is involved to do this? Please help me out. I know that many wide fronts are 3 or 4 bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 10:27pm
3 bolt are the earlier and correct to the WD, but four bolt will work also.  Changing it out isn't that hard to do, just work.  Make a good support for the frame rails.  I made one out of angle iron and made a U that sits solid on the ground.  I picked up the two vertical bolt holes by the front of the engine.  Took off front wheels, popped the pin out of the u joint from the steering shaft to the shaft that goes to the steering wheel.  Unbolt the four bolts on each side of your narrow front bolster.  What I had to do was wedge something between the frame rails to somewhat spread them.  It would help to have the bolts out of the front engine support and the radiator to facilitate that, but sometimes the bolster will come out without doing all that.  Once you get the narrow front one out, put the wide front one in, and bolt in and connect the wide front underneath.  If you're lucky, you can find a narrow front that bolts underneath the wide front bolster, so if you want to switch back and forth, you won't have to remove the bolster ever again.  I wish I had pictures, but I dont'.
bigfish_Oh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 11:16pm
I changed 2 tractors in the yard(grass) by myself. The hardest part can be the steering universal.
1941 WC sat for 29 years,started & dynoed 27 h.p.
1957 WD45 Grandpa bought new,factory p.s.,added wfe
1951 WD, factory p.s.
1960 D14 HnMk IV BkHoe 4 sale
2014 HD Tri Glide
2009 GMC CC SLT Dually
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 12:57am
the wd45 i just bought has a rear axle out of a red combine for a wide front. some may call it jimmy rigged, i guess i would have too until i saw it, now it's inginuity! and it works!
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 11:01pm
larry...you said it all about the steering "u"joint i have removed several of them and it can be a bear.if you have power steering its a breeze the splined coupling.slides out of the bottom of the power unit
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 11:15pm
It gets more complicated trying to figure out what the last person put it back in with and where they welded, I have yet to find one as original.
   Speaking of the p.s., The coupling below the factory unit only slides a little down the shaft ???? I have sanded my shafts down very little to let coupling slide and shaft can installed or taken out very easily to service joint.
2014 HD Tri Glide
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 11:29pm
let me repeat that for those who may have missed it, "The hardest part can be the steering universal."  Larry is right on on that one, if somebody messed up that roll pin, or if it is worn uneven, You're in for an adventure. I've had some come right out, and then there's the other ones! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2010 at 11:38pm
 I remember, 2 x 6's, cement block, couple sockets, long extensions, hammer, bigger hammer, %*@# and more $#%&*. This is where I ordered my roll pin punch set. I was in the yard fighting with it when the UPS truck pulled in with my new toys/tools.
   I am not afraid of them any more, respectful, but not fearful
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 8:14pm
big fish,you have it figured out and flying straight and level. you are not the larry trout that went to school with my brother kenny freck are you???
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 8:33pm
The last universal I disconnected I dissed it with the blue flame wrench. I just had to cut me a new piece of streessproof to replace the input shaft to the pedestal. The pins I have removed were solid and were swedged into a chamfer on both sides of the u joint.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 8:35pm
No, that's not me. I do know of 2 other unrelated LT's close to me, I've met & exchanged business cards with one of them and got UPS(ford stuff, knew it wasn't mine) that was the other's !!
2014 HD Tri Glide
RickM(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 10:26pm
Guess I was lucky when I put power steering on my 45 recently. The solid pin in the universal came right out and went back in with no problem. Now I am worried that it may not stay in!!! I would hate to have that thing drop out out while I was driving it!!
Missouri Allis Chalmers Club Member; 1954 WD45 (NF), 611LTD & 811GT Lawn Tractors
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigfish_Oh Quote  Post ReplyReply Direct Link To This Post Posted: 14 May 2010 at 11:35pm
I think I put a zip tie thru a less than pressed tight roll pin before
2014 HD Tri Glide
Post Options Post Options   Thanks (0) Thanks(0)   Quote RickM(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2010 at 6:47am
Larry, Good suggestion but mine has a solid pin, not a roll pin. Maybe I will take it out and reinstall with Loc-Tite.
