links for 1947 WC
dbaileyky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbaileyky Quote  Post ReplyReply Direct Link To This Post Topic: links for 1947 WC
    Posted: 12 May 2010 at 8:44pm
can any one send me a link with detailed pictures and info for recommended fluilds and fluid levels and areas to check drain and fill for my WC
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 8:50pm
I don't know of any links, but an operator manual from one of these site vendors can point you in the right direction.  They are very affordable.  Just trying to help!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 8:57pm
Pretty simple tractor..... agree with the recommendation to buy an operator's manual. That said, 10W-30 in the engine (fill is at magneto, dipstick - well....); tranny - use Hy-Trans; finals 140 weight. This should get you started.
WC, CA, D14, WD45
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 8:58pm
Help support this site. Go to the link and get you a service manual. It will be well worth the money in time saved on regular maintenance.
http://www.3000toys.com/allis/products.asp?cat=2&type=books&find=ACWCWFRC
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 9:03pm
Not having hydraulics, good 90 wt gear lube would work in your tranny-differential and in the finals. You shouldn't have to worry about the tranny getting too thick down there in Kentuck.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dbaileyky Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 9:08pm
thanks everyone i want to get a manual i saw some post elsewhere that some of these manuals were poorly printed to the point of unreadable...these appear to be good looking manuals thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2010 at 9:10pm
I would stay away from Jensales if you wan to be able to read and see pictures. I have a parts manual from Darin and it is great.
