starter issues
Robacpuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Topic: starter issues
    Posted: 22 May 2016 at 8:44pm
What is a good starter to use on a 400 cube wc. I have a gear reduction starter on know and 2 12 volt batteries. It has all it can do to start my tractor. I know people use a diesel starter off a 45 diesel. I run 11to 1 compression.
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 9:14pm
I fixed mine by running A ground direct to the starter use 2/0 cable
allispuller View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allispuller Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 10:35pm
Get a starter from hi torque imi out of California gonna run ya around 600 bucks but it'll start it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 5:27am
How did I ever get by with a standard WD45 gas starter with the center armature bushing????   I had good welding cables for pos and neg to the starter, one 850 CCA battery and 390 cubes at 12 to 1 compression. Ran this way for several years without any issues.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 5:33am
I also put a ignition switch on mine I get it rolling over then hit the switch
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 7:35am
Rob,
I can build a pretty stout Starter motor from a Delco core if you have one to fit your WC. Usually runs around $475. or so if interested. I've done bout' a dozen of em' so far for our pulling customer's and everyone has been more than satisfied...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 7:17pm
I also have batteries up front does it Make a difference having them closer to starter. Or just bigger cables and ground to starter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 2:20pm
Its always a good practice to have your power source as close as possible. If you have to keep them up front, run cable the size of sewer pipe to cut down on voltage drop....
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2016 at 8:04pm
Patrick what size tires do u use on your tractor and rpms in open class. What do u have for cubes. How much hp. I have 400 cubes tried Dino and broke drop box. I was at 0ver 90 when broke. U have awesome looking tractor. What tire size. I have 15.5 38.
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2016 at 8:02pm
I have 15.5x38  Its 350 ci  don't know the exact HP I run close to 2950 in the open class
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2016 at 8:11pm
re:
Steve@B&B
That's GREAT Steve ! LOL, you mean I can't pull 500 AMPS through 20 feet of #18 wire ??
Sad thing is I KNOW someone who used 3/8 copper 'bussbar' for his battery feeds pushed it through 5/8 black rubber garden hose to insulate it. It was pretty and no voltage drop either !!
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robacpuller Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2016 at 9:22pm
How do get it to run that high rpms,what Gove spring do u use
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 9:40am
I use  a 170 spring worked on the weights and the  throttle rods I made a spring adjuster and a adjustable rod on the carb side  the carb head and manifold  has had a lot of work done to it
This page was generated in 0.065 seconds.
