wc tire sizes
firecowallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Topic: wc tire sizes
    Posted: 22 May 2016 at 7:24pm
i currently have steel on my wc and my back cant take it any more so i bought a set of round spokes i had  always thought they had 24 in tires on them but  they measure 27 in out side to out side  across the center of the hub  so what size tire do i order 12 -28  thanks for info  u can give
allis g 7045 200 wd45 wd45d c ca 6080 u
irlbeck A-C'S View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 7:39pm
You're correct 12x28
B,C,CA,(2)WC's,(4)WD's,(2) WD45'S, 45Diesel, (2)D12'S Series 2, D12 Hiclear,(2)D12 Series 3, HD3, D17NF (3)D17 Series 4 Diesels, M-100 Grader,8550,A few Lawn tractors lots of other AC stuff
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 7:48pm
If you're measurement of 27 inches is outside to outside of the rim flange, then it's probably 24 inch outside to outside of where the tire actually seats on the rim.  The inside to inside measurement should be about 23 1/2 for a 24 inch rim.  A 28 in. rim is close to 31 in. outside to outside across the flanges.
Post Options Post Options   Thanks (0) Thanks(0)   Quote irlbeck A-C'S Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 8:48pm
Oops. Was in a hurry and didn't read you're question well enough. Completely missed the part about the round spoke rims and you're measurements. I was thinking about my WC's having 28in rubber. Phil is correct with the outside measurement of a 28in rim being nearly 31in.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 9:32pm
A rim has three diameters. The center where the spokes are welded is dropped to allow putting the tire with wire in the beads in place without taking the rim apart. Then there are the two bead seats that are actually angles. The flat ones are the tire diameter, then the flanges set the tire bead width. In the old days that was the width on the tire, now the tire width number is the maximum width of the tire which is wider than the bead to bead distance. The outside diameter of the rim is the top of the flanges and should fit the tire bead shape, but isn't a number on the tire. Tire manufactures put out handbooks with tables of the rim and tire dimensions. One of the handiest ones is from Titan/Goodyear and can be found with a search for Titan/Goodyear Ag Tire Handbook.
Gerald J.
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 10:20pm
i have lots of spoke wheel wc'' tractors. all of them are 24'' s. have a few with 14.9s' looks good. later ones with bullet tank went to cast center wheels 28 inches 13.6x28
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 8:02am
so order 14.9 x 24 tires  am i reading this correctly
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 9:28am
I have a wc with 28" round spokes too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 11:26am
so could the rims i have be wrong ones maybe for a uc ?
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 11:31am
UC has bigger bolt pattern, not the same
Alex09(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alex09(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 1:08pm
I have a 36 wc with flat spokes that has 28" rim on the back. I think the 28" spoked rims were steel cut-offs.
www.awtractor.com
A&W TRACTOR 920-598-1287
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 1:41pm
 Yes, flat spokes are steel wheels cut down. Original wheels with either flat or round spokes were never welded to the steel wheel or rim.
 tire size has to match rim diameter and the rim diameter is NOT measured across the outside diameter.
http://www.goodyear.com.jm/img/image015_tcm1076-64397.jpg
Edited by CTuckerNWIL - 23 May 2016 at 1:43pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 1:46pm
To me 14.9 seems a bit wide though that is the size on my MF-135. Measure the distance between the flanges and go to the ag tire handbook and the table on recommended rims. Mine says the recommended rim for 14.9-24 and 14.9-28 is 13", but 12" is also approved. For 14.9-26 only 12" widths are recommended and approved.
Long ago I had an 8N with 14.9 tires on rims a bit narrow and when those tires were old and gray and hard it took a tire guy with lots of power tools a whole afternoon to replace them.
I suspect your rims are more like 11 inches and the tire that fits best is a 12.4.
Gerald J.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 3:20pm
I have a WC with 36" round spokes
AaronSEIA View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 7:20pm
I've seen WC's with 12.4 on them and they look way too small.  A 14.9 "balloons" a bit much on the stock rim, but really looks the best of everything out there.  I think  a 13.6x24 would be perfect.
AaronSEIA
Thad in AR. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 7:22pm
You have 24" rims. I just measured mine and they measure 27" as well outside to outside. Mine have 14.9 24's on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 8:02pm
A 12.4 looks anemic on a WC. 13.6 not bad but a bit narrow in my opinion. A 14.9 is the same size tire that came on many of the WC's.  Just might have been marked as a 13-24  or 11.25-24. All the same size tire mounted on 8 to 13 inch rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 8:14pm
re measured my rims and they are 10 in wide and 27 in tall  and they are not cut offs factory round spokes i  the guy i got them from says they had 28s  on them but like i said i thought they should have had 24 s just really confused
Post Options Post Options   Thanks (0) Thanks(0)   Quote firecowallis Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 8:15pm
thanks for all the help
