stuck sleeves
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Topic: stuck sleeves
    Posted: 22 May 2016 at 5:18pm
Trying to remove (In frame) W201 sleeves. Looks like the PO applied some kind of black sealer to the sleeves and they are stuck tight.
My trusty sleeve puller won't budge them, my puck actually bent cup shape
Any ideas?
Last resort will be to remove the engine and crank and pound them out.
Charlie
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 6:57pm
If you can get something to push up past the crank on the bottom you can use a jack to help push them out
TREVMAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TREVMAN Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 7:25pm
I used or tried to use a store bought puller, it broke. I built a heavier one, it broke. Then I got serious, and welded up a heavy home made unit after a little thinking. It worked. I was surprised by the force required to pull the sleeves. I used 2 by heavy wall tube, a 7/8 ready rod, and made a bottom plate 3/4 thick. I'll see if I can send you a pic, its nothing fancy but I made it out of "in stock" parts (also known as junk) so it didn't cost much, and it works. Trev.
Edited by TREVMAN - 22 May 2016 at 7:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 7:52pm
Thanks.
Had no issues with previous rebuilds, they always came out pretty easy.
Always has to be "fun" :)
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2016 at 9:59pm
Charlie,
Yes always something new to deal with. Good luck. Wonder if a little heat might break the bond?
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2016 at 9:58pm
When I pulled sleeves on our 170 I had the same problem. Not having a real sleeve puller, I used my 2 jaw puller on a couple wood blocks. Then using all thread, a rod coupling nut and steel plate I attached a slide hammer above puller and a nut under sleeve to add tension. It took more time to set it up than knock it loose.
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 1:58am
I used C channel on top of head with 3/4" threaded rod double nutted on the bottom and a 2" piece of 150 year old oak as a pusher. I'll also suggest using some heat to soften the JB welded in sleeves.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Bull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bull Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 10:51am
I had the same problem once. A friend has a 40 ton hydraulic puller, he had all 6 out in 30 minutes. No pounding, just slow and steady.
WD45 Diesel, RC,CA,IB, B, G, 616, Early B-10, D-10, Terra Tiger, 95G spreader, SC blade
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 1:50pm
Maybe some methylene chloride paint stripper?
cdreb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdreb Quote  Post ReplyReply Direct Link To This Post Posted: 24 May 2016 at 2:04pm
When I worked at the Mack dealer we used a welder and welded around the sleeve at the midsection. Of course we used wet rags and protected the crank. Sometimes it took a couple of tries. Food for thought.
B,C,5020,D17,(2)-190XT's,220,D21,7060, Agco LT70
