What oil are you running in your gas tractors
Tim (Cent.WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Topic: What oil are you running in your gas tractors
    Posted: 20 May 2016 at 4:47pm
My son and I have been arguing about what is the best oil weight and brand to run in our gas AC tractors (B up thru a 180G). I was wondering what everyone's opinions were and what they were running. I know this has been discussed before, but I wanted a new post with unbiased opinions to let him see what everyone is running.
Thanks,
Tim
Ky.Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ky.Allis Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 5:43pm
Shell Rotella 15/40 works well for me. I use it in everything on the farm--Gas or Diesel
wbecker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wbecker Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 5:49pm
Any detergent oil, personally, I prefer multi weight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 5:53pm
Any GOOD multi weight detergent oil. 35WC, 38B, 51CA, 54WD45, and  60 D17.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 5:59pm
Rotella 15w40
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 6:00pm
Usedta use amsoil 30 weight, now I am changing to Mobil 1 full synthetic 10w30.  We'll see...
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 6:02pm
Rotella 10/30 as I use tractor in the winter some.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 8:18pm
Kendall 15W-40 diesel grade oil in all the tractors gas or diesel for the last 20 years.
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 9:13pm
If you start any of your old tractors in cold weather, Mobil 1 Turbo Diesel 5w-40 would also be a good choice.  It is also rated for gas engine use.
Mark
GTH-L Simplicity
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 9:16pm
Whatever 10-30 is cheep. Any new oil is seperior to the ND straight wieght it had when new. I change the oil and filter every couple years or so. Been doing that for decades and they still work good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 9:19pm
Im with Dave... 10 w 30 detergent oil ... Wal Mart brand in all my smaller tractors. Use Mobil 5 w 20 in the trucks and SUV.
Carl(NWWI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Carl(NWWI) Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 9:50pm
Caseih low ash 30w goes in all my gas tractors, and caseih #1 30w goes in all my diesel tractors.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 10:14pm
  the caseih low ash oil for gas tractors is about the best.   the rest of the oils are great but gas tractors are kind of a breed of there own.
Jim Hancock View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Hancock Quote  Post ReplyReply Direct Link To This Post Posted: 20 May 2016 at 10:17pm
10w40 Valvoline synthetic. Or 10/30 in winter.
Edited by Jim Hancock - 20 May 2016 at 10:18pm
How blessed we are by HIS GRACE!
breedman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote breedman Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 1:05am
I use 10w30 in my gas engines for years and 15w40 Rotella in my diesels
cpg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cpg Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 5:38am
Original manual for all my old tractors (which are gas) say 10W winter and 30W summer so I also run modern conventional 10W-30. I don't run synthetic. I don't think these old engines were designed with close enough specs to really benefit from it over conventional.
jgrag984 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jgrag984 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 6:57am
Amsoil 10W30 full synthetic with Napa Gold filters. Use mine year round.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 6:59am
F/S 10W30 OR F/S 15W40 designed for farm use.
Dan73 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 8:08am
The oil I add to my tractors has alot to do with which part is leaking. Lately I have had to add alot of hydraulic oil but I just got the power steering fixed so it should just be time to change the 10 w 30 motor oil. Someone told me a long time ago the old gas motors where designed for 30 weight and that was what you should run. Never seemed to be a seasonal issue running 30 weight in the d17 year round here. It has run on that since the 60s when my grandfather bought it and the 226 is still running great. That is one well built motor.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 8:20am
John Deere Plus-50 ll  15W40 Premium Engine Oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 9:23am
I know it's picky, but there is no 30w oil-----------------the "w" after an oil viscosity denotes that it meets the winter specifications for that viscosity.  These specifications stop at 25 weight oils.   Wink
Actually, when new, some of the engines probably did have as tight of clearances as today's engines.  It's just that some also had looser clearances than today's engines as machining tolerances were not as well controlled back then.
Edited by 427435 - 21 May 2016 at 9:25am
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 9:57am
wally 10w30 synthetic since modern oils gave flat tappets the finger
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 10:48am
Even the worst modern oil is better than what was available back in the day. Change the oil and change it often.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 11:00am
Mark good point on the tolerances.   The modern motors running 0w20 oil will start to use alot of oil as they get older I have been told. Guess that 0 weight that flows like water is hard to keep in an older engine.   But I think they mostly care about the first 100 miles when they design cars now. Beyond that I think they want them to be traded in anyway. These old tractors where built to last.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 11:07am
From the old old school.
That is when we sold them new in the 30's to the 60's.
In the engine we used sae 30 non detergent oil.  At that time we did not have detergent oils available.  In fact, when we had customers who bought used tractors they started using the most modern detergent oil available.  Worked too good since it cleaned out all the gunk that was keeping the engine from burning oil and leaking.
We would go out with five gallons of our sae 30 oil and change the oil.  It worked and the owner got quite a bit more life out of the unit before a major overhaul.
In the hydraulic we used sae 20 NON DETERGENT oil - 10 NON DETERGENT in really cold weather.   Some of our customers used detergent oil and they ended up with a case full of foam.
That was how it was in my olden days.
Now I am delighted to hear the excellent results from the newer oils in both the engine and hydraulics.
Good Luck!
Bill Long
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 12:29pm
Rotella 15-40 from Wally World as the cheapest place I have found. Filters on gas D-Series changed at 100 hours with NAPA Gold or WIX equivalent.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 1:54pm
a note on oil - Al Gore and is minions have impacted oil.  The newest oil for the tier IV is not a "premium oil" . Our resident engineer did some research - the IV diesel oil has had a lot of ingredients that "pollute "  when consumed, removed.  They charge us more for less. The latest oil is fine I am sure, but is developed not for lubrication , but to pollute less when "used" by the engine.   Also automotive oil several years ago had some selenium compounds removed as all cars use roller tappets.  This automotive oil will wear out flat tappet lawn mower and tractor engines.  Use appropriate Briggs, Kohler oil in mowers or diesel oil.  Use the same oil  in gas tractors as you use in the diesel.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 2:26pm
Hard as it is to believe, but WalMart is the third ranked oil in standard oils. So go figure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim (Cent.WI) Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 10:10pm
Thanks everyone for making my point to my son, I have been running Rotella 15-40 for years in all my tractors, gas or diesel and he was trying to tell me it was to thick for the gas tractors. Thanks again
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan73 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2016 at 10:17pm
Tim that would all depend on how tight the motor is. If you rebuild the motor and everything was measured and right at spec it would be alot different then a motor which has who know how many hours on it over 60 years.
This page was generated in 0.408 seconds.
