M&W 4.125 AP-46 pistons |
Unstylish
Joined: 11 Mar 2010 Location: Southwestern Points: 152 |
Topic: M&W 4.125 AP-46 pistonsPosted: 12 May 2010 at 5:55pm |
I just picked up an almost new set of AP46's and sleeves that were in a WD in the junkyard. What are the specs, especially the compression distance? Looking at putting them in an offset grind combo, so height matters..thanks..
CTuckerNWIL
Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
Posted: 12 May 2010 at 7:04pm |
The stroke, rod length and piston height from wrist pin to top are all numbers to take into consideration. If you have the pistons you can measure from the wrist pin center to the top of the piston.
DrAllis
Posted: 12 May 2010 at 7:14pm |
If they are SP-46's, combine them with a 4 1/2 stroke crankshaft (WD45 or D17) they will need .170" or so removed from the tops to keep from hitting the cylinder head. This is a nice set-up and will require real good gasoline (like 100 octane or better). Compression pressure while cranking with the starter should be around 240 psi.
DrAllis
Posted: 12 May 2010 at 7:32pm |
Ignition timing will also have to be backed down to around 15 to 20 degrees BTDC (instead of 25 to 30 degrees BTDC) and should be adjusted on a dynomometer for best results.
Unstylish
Posted: 13 May 2010 at 6:26am |
Thats roughly what I needed to know..thanks!
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 13 May 2010 at 11:27am |
Question for DrAllis. What is the difference between a AP-46 and a SP-48? Reason as I just removed a set of SP-48's from a WC? - AL
DrAllis
Posted: 13 May 2010 at 12:29pm |
I really don't know....I KNOW what SP-46's are.....AP-46 is a newer?? version or is it a typo?? ("S"and "A" are next to each other)
Larry(OH)
Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1580 |
Posted: 16 May 2010 at 9:47am |
I haev a piston showing where you need to fly cut for clearance with this setup (long story):( It definately cranked hard
'40 WC puller, '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
