7580 cab swap? |
Post Reply |
Peterson
Orange Level Joined: 05 Mar 2011 Location: Westboro, Wi Points: 862 |
Posted: 19 May 2016 at 11:44am |
Ok guys as I sit in the 7580 disking, I can't help but ponder what it would take to graft a 4w cab onto this thing. Are the main frames the same width? Cables and hoods should be easy. Would the electric solenoid high/low valve fit on the original 7580 valve? Or just put the push buttons in the floor? Think it would be cool, and be much more operator friendly!
7095-685I at 255hp, 8070-225HP,8050-210Hp,8030 with 155HP,220 with 670T engine with A-pump, 7580, 185 with 140HP, 2-6080's,6070, S4 D17,wd45,CA,st34 agco, S1 D17 with 3500MK2
Peterson
DSeries4
Orange Level Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7332 |
The 8000 cabs are much wider, so I doubt the mountings are the same. I don't think the 8000s had the buttons on the floor either. It's a nice dream, but I think it would take a lot more to get everything to work properly.
Kevin in WA
Orange Level Access Joined: 08 Feb 2010 Location: Lynden, WA Points: 611 |
PD valve on 4w220 and 8000's is different, and mounts on the side of the transmission instead of the top to make room for the cab.
Peterson
Are the transmission castings the same. Could one swap the 4w/8000 series valve onto the 7580's? Or to make it simpler, just swap a powershift into it! Lol
ILGLEANER
Orange Level Access Joined: 13 Sep 2009 Location: Willow Hill,ILL Points: 6448 |
the hardest part would be finding an 8000 donor cab cheap enough. They only made 175 220s
Peterson
4w305 should be the same cab.
ILGLEANER
Yes they are.
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8633 |
my son and I may take a shot at putting a power shift into a 7580 this summer. If we do, I'll be posting about it on here. Darrel |
SHAMELESS
Orange Level Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
ahhhhhh....someone else...that don't gots nuff to do! lol
darrel in ND
I was going to invite you up to help us SHAMELESS, cause I know you don't have enough to do. But if you helped us out, it probably wouldn't have brakes that worked when we got done. Lol.Darrel
DrAllis
Orange Level Access Joined: 12 Sep 2009 Points: 20494 |
Installing a Power Shift into a Power Director chassis will result in a speed reduction in road gear, and all HIGH Range gear selections....about 20% slower in all.
darrel in ND
It will go in there, though. ........? Darrel
Dmpaul89
Orange Level Joined: 06 Mar 2013 Location: Edwardsville,IL Points: 1689 |
Man that prototype looked sweet. should of just rolled with that. I never liked the 8000 series hood as much
DIESEL
Silver Level Joined: 26 Aug 2013 Location: Sandhills Points: 259 |
My cousin put a 8000 series cab on a 7040 and it looked amazing you couldn't tell it wasn't factory.
Peterson
PICS? My idea is to take a 8070 powershift fwa and make it a 7080 open station. Man that would look awesome!!! Now for putting a powershift into the 7580. According to the agco parts book the powerdirector trans casting is the same between7580 and 7060. So a powershift should "bolt" in. Only thing is the PTO/hydraulic straight shaft is different between the two. So if the 7060's is shorter, have a new longer coupler made to couple the drop box to the powershift. That was my idea. |
joe
Silver Level Joined: 30 Nov 2009 Location: SW Ontario Points: 137 |
Yes pictures of that please. Would love to see that.
DIESEL
Wish I could get you some but he bought an 8070, so the 7040 didn't get used much for a couple of years and he traded it in on a new Rowse v-rake. I could of cried when I found out I would have loved to own that tractor.
Post Reply | |
