12v coil on 6 volt system
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Topic: 12v coil on 6 volt system
    Posted: 12 May 2016 at 7:17pm
Can I put a 12 volt coil on a 6 volt system without any concerns?
THink my current 6v coil needs to go back to china, planning on doing a full conversion in a couple of months so wanting a to short term fix with a 12v coil.
Thoughts?
D17 Series 1
Allis B- 1939
Allis B- 1945
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 8:28pm
It *might* work. You'll have a weaker spark. I wouldn't recommend it. If it doesn't work you'll still have to buy another coil. Extra $$$. I'd recommend that you buy a 6 volt coil now and add a ballast resistor when you convert to 12 volts.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 9:06pm
A 12 volt coil designed to work with an external resistor should work good on 6 volts but a coil wound for 12 volts or with an internal resistor for 12 volts will give a weak spark on 6 volts. It will depend on the coil details that we have no way of knowing of how bad the spark is at 6 volts, especially when the battery is pulled down while the starter is cranking and may be less than 6 volts.
Gerald J.
This page was generated in 0.053 seconds.
